2720 Oil Question - How dirty is your oil?
   / 2720 Oil Question - How dirty is your oil? #1
megaboz
Fairmont, WV
'17 2032r (soon)
I just checked the oil on my tractor after 11 hours (and even before I ran it), but it still look super clean. I expected it to be black by now, maybe I was expecting too much.
Anyone else with still low hours on it and still have super clean oil?
I know diesels run cleaner, but I expected it to at least look dirty by now.
   / 2720 Oil Question - How dirty is your oil? #2
How dirty does the oil in your Dmax get after 200 miles? About the same as 11 hours with your 2720....
It shouldn't get real, real black even after normal run-time of 200 hours - unless you're rototilling or pulling a disc harrow the entire time!
After your 50 hour break-in the oil color should look about like your Dmax oil @ 750 miles.
AKfish
   / 2720 Oil Question - How dirty is your oil? #3
When my 4210 was new, I remember the oil was still very clean after the first 25 operating hours, but I changed it and the filter anyhow. Every new engine (aside from 2 strokes) I have owned has been given an early oil and filter change. I do that because I have felt it's better to do an early oil change rather than let the crud in a new engine stay in until it's time for the first scheduled change.
When I posted my experience (early change) a number of TBN members informed me I should have waited longer for the first change, because Deere had filled the engine with "break in oil" at the factory. Not sure if that was true or not, but after nearly 900 hours, my oil consumption is zero.
   / 2720 Oil Question - How dirty is your oil? #4
It's a fact.. JD fills the crankcase with "break-in" oil and they strongly recommend that you keep the oil in the engine for the recommended hours to ensure that your tractor does not burn oil later after the break-in period.
Check this out:
Frontier Power Products - Deere Break-In Oil
AKfish
AKfish
My Dmax was black as black at 250 mile. My kubota was black at 10 hours. That is the reason for my question. I was concerned that the oil pump wasn't pumping.
Thanks for the replies.
   / 2720 Oil Question - How dirty is your oil? #6
If your oil pump wasn't working, and the red oil pressure lite on your dash wasn't working either, you would have a seized engine after the first minute of operation, or sooner.
   / 2720 Oil Question - How dirty is your oil? #7
Check this out:
AKfish
Thanks for info, neither my salesguy (who I had real trust in) nor the manual that came with my new tractor said anything about this issue. When I was at the dealership shortly after my original purchase to pick up hydro fluid and filters for the fluid and filter change recommended at the break in interval, I mentioned that I was going to service the oil and filter early also.
HE NEVER SAID A WORD OTHERWISE, although he DID say he was pleased I was going by the book for the initial hydro fluid and filter change. That was recommended at 50 hours, along with the initial oil and filter change. Seeems to me if Deere felt so strongly about leaving the break in oil in the engine UNTIL 50 hours, they should have specified so in the owners manual.
I just checked my records, initial oil change was at 31 operating hours and not 50. I did notice at the time that the OEM oil filter was about 25% larger in size than the one purchased over the counter at the dealership.
   / 2720 Oil Question - How dirty is your oil? #8
It's not the best pic,but this is all the darker (dirty) my oil has been.When I changed it out at 50 hour it was no different than this. There is 28 hours on this oil.
I didn't put break-in back in either.Was told (dealer) that 50 hours is enough. There are links telling you that it should go to 100,and there are links telling you it's not necessary.:confused2:
Oh well,too late for me to change back now anyway.
Greg
   / 2720 Oil Question - How dirty is your oil? #9
Greg
Never would have thought about trying to show a pic that way...smart of you. My JD, I changed the oil and filter in the fall at 790 hours, it just turned to 842 and that pic of yours is about the color my oil is after 52 running hours.
   / 2720 Oil Question - How dirty is your oil? #10
Greg
Much depends upon the model of tractor you have. 50, 100; my new 5075M is 300 hours on the break-in oil!
Older manuals may not have the correct info. If necessary, you can view the latest owner's manual version for your tractor on-line @
JohnDeere Products & Services
AKfish
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A55218)
2012 Ford F-150...
2011 New Holland Boomer 90 MFWD Utility Tractor (A55301)
2011 New Holland...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55218)
2021 John Deere...
2018 KUBOTA SVL95-2S SKID STEER (A52705)
2018 KUBOTA...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
