Harbor Freight Quick Attach on sale.
   / Harbor Freight Quick Attach on sale. #2
If you scan it and post it, HF will accept it.
   / Harbor Freight Quick Attach on sale. #3
It's a close-out and on back-order. Not sure about that, but you might read the reviews, seems to work for some, some not. :confused2:
   / Harbor Freight Quick Attach on sale. #4
Paid $70 for mine and took it back. Bought a Speeco E-Hitch and could not be happier. The HF was just not made right and would not even work on Woods quick hitch ready stuff. YMMV
   / Harbor Freight Quick Attach on sale. #5
This is a good deal for those willing to do a little work. Mine works for everything after I modified the hook bolts to be narrow clearance pins and after I ground on the hook for a while to open it up to the specs. If you are willing to spend an hour or so fixing it, it will work as well as any other QH. If you aren't ready to do that it's a badly made Chinese knock off.
   / Harbor Freight Quick Attach on sale. #6
Very well stated. The top hook on mine was too narrow so it would not let the implements bushing to slip to the bottom. Also, the top hook did not extend far enough out of where it was bolted to the hitch and it hit on the implements linkage. You are right though, nothing that could not be fixed.
The best part about the E-Hitch is the fact the lower hooks are made for 7/8" lower pins and do not require the use of adapter bushings. I have 7 implements and at $16 a pair for the adapters, the Speeco more than made up the difference in price.
1965 Rogers Low Boy Trailer (A57453)
1965 Rogers Low...
SKID STEER ATTACHMENT ROCK SIFTER WITH BUCKET (A58216)
SKID STEER...
Hydraulic rail grinder (A56436)
Hydraulic rail...
2024 EL45 Mini Electric Wheel Loader (A56857)
2024 EL45 Mini...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
