Tach quit after welding DX35
   / Tach quit after welding DX35 #1
DANOCHEESE
Gold Member
SW Minnesota
Forgot to unhook battery when I welded a bracket on the bucket now the tach quit working.
Any ideas manul does'nt indicate that the tach is fused.
   / Tach quit after welding DX35 #2
are you supposed to unhook the battery before welding???? never knew that. I never have, i guess ive just been lucky. for now on i will though
   / Tach quit after welding DX35 #3
Its quite possible it blew a diode or something of the sort on the circuit board... Hope its not as tough to track down as I think it may be. I doubt it would blow a fuse. Did you clamp your ground close to the work area?
   / Tach quit after welding DX35 #4
Ya, i clamped the ground on the bucket when i welded some plate to thicken the top of the bucket for a trailer ball. I really never heard you have to rmove the bat cable. Sorry to hear of your problems.
   / Tach quit after welding DX35 #5
I have heard that if you don't remove the battery on a car, you can fry the computer, and just about every car has one. The same would apply to some tractors.
   / Tach quit after welding DX35 #6
You just should have bought a nice OLD piece of American iron, and you would not be having this problem.
   / Tach quit after welding DX35 #7
true.....it would have been hard to weld thru all the rust LOL... sorry...couldn't help myself:licking:
   / Tach quit after welding DX35 #9
It could be caused by the welding, or it could be something totally different and just a coincidence????
How old is the tractor? Still under warrenty???
I have welded on vehichles and tractors and have never unhooked a battery either. Never had any problems. But I think my tractor has minimal computers and the tach is cable driven.
The newest thing I have welded on was a 1995 with a OBD I 5.9L dodge gasser. Again, no problems there either.
How is the tach driven on one of those. Is it a crank sensor or something? (since no spark or coil to feed tach). Might want to start at the sensor and see if you are getting any supply voltage, and see if you are getting a signal out to the instrument cluster as well. A good DVOM will come in handy.
Good Luck
   / Tach quit after welding DX35 #10
I have a new dk45 tractor and ive welded on the bucket and a post hole digger while both were installed on the tractor.....mind you i wont in the future. But nothing has happened. Have electronics all over the place on this tractor
LAPTOPS AND ASSORTED POWER CORDS (A53843)
LAPTOPS AND...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
