pharmvet
- Joined
- Sep 28, 2008
- Messages
- 534
- Location
- North East TX
- Tractor
- Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
The fuel gauge on my tractor has never worked properly since I bought it used. I had it in the shop for some other little issue and mentioned it. They cleaned the "prongs" on some connection and it began to work somewhat but would only register 3/4 tank even when it was brimming to the rim with diesel. I took it back in to have a quick connect installed for using a grapple and mentioned it to them again. They then replaced the sending unit. Since they did not fill up the tank to check it, they could not be sure if it was fixed or not. I took it home and filled it up and it still only registered 3/4 tank. I realize this is not a super huge deal, but I would like for it to work properly.
Is there any way to fill up the tank, and then manually move the fuel gauge needle to register full? Will this solve my problem? thanks
