JD Sabre 2048 Deck Belt routing
   / JD Sabre 2048 Deck Belt routing #1
davemskinner
Pulaski, NY
GL4330 HST
Hey All,
My son-in-law has a JD Sabre 2048 and got a stick caught in the belt. The belt flew off and he bent the main pulley. He nor I can figure out the belt routing to put it back together. The manual only shows a two belt setup and his is only a one-belt configuration.
I'm not a newbie to this stuff but this is sure kicking our butts.
Any help would be extremely appreciated.
Thanks,
Dave :thumbsup:
   / JD Sabre 2048 Deck Belt routing #2
Looking for info on your mower. Does the deck have 3 blades?
3 blade belt route: John Deere - Parts Catalog
I am not sure this is yours. Does it look similar?
   / JD Sabre 2048 Deck Belt routing #3
I had that mower.It was a 3 blade unit. I don't remember the specifics, but I thought it had a routing plate on the mower deck. ARE you replacing the drive belt or the deck belt. I am pretty sure you have to take the deck off to replace the drive belt. The mower belt is released by a handle that is pivoted to move a pully toward the outside of the deck.
   / JD Sabre 2048 Deck Belt routing #4
My JD Parts link above: If page shows no information: Do this:
1: Insert in {model box} insert [2048]
2: {Click on} (9102-L2048 Scotts Lawn Tractor)
3: {Click on} (Pictorial Index)
4: {Click on} (85-1-D8 Mower Deck & Lift Linkage)
5: View Picture on right side of page.
On my computer the above link showed everything with 1 click, but when I came back later screen was blank. Sorry. The above instructions should get you to a picture of the belt routing. If not, let the forum know it did not work for more information . Try This Link
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Yes very similar. This is not the layout that my son-in-law had in his manual.
But it does look like the one. The way they show the idlers is a little confusing because the picture shows then as three different sizes but they all have the same "item" number. Not that it matters much. The pic is what I needed.
Thanks sooo much!
Dave
The routing plate is nowhere to be found. I was hoping that the decals kit would have it but it does not. Oh well...
Thanks for your reply.
Another great post! Thank you. I was able to get the picture from your first post.
I have a 1984 JD 950 in my garage that I bought to fix and flip. It had a bad tranny (which I knew). Little did I know that the tranny had already been apart and butchered with a welder. Long story short, almost a year and $3K later, I finally have all my parts and am looking for the time to start putting it all back together. I never would have have thought a 1984 machine would be so hard to get parts for.
I guess it serves me right for just jumping in and not doing my homework first.
Thanks again for the help. I should be good to go. I will post an updateafter we get the Sabre going again.
   / JD Sabre 2048 Deck Belt routing #8
The belt should go from the main pulley to the far left blade, then to the middle, and then to the far right. (if I remember correctly)
   / JD Sabre 2048 Deck Belt routing #9
Dave, that belt routing is highly unusual so I can see why it would be hard to figure out without a diagram. Good luck on getting it back on. Ray
2005 International 4200 VT365, Super Cab (A52384)
2005 International...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2017 International DuraStar 4300 Truck (A51692)
2017 International...
UNUSED HURRICANE G350 MINI CONCRETE MIXER (A51248)
UNUSED HURRICANE...
(APPROX 100) UNUSED LANDHERO T-TOP BOLLARD (A51248)
(APPROX 100)...
2016 CANYCOM SC75 STAND ON DUMP BUGGY (A51246)
2016 CANYCOM SC75...
