Stihl recall on some products for gas caps
   / Stihl recall on some products for gas caps #11
I got my recall notice yesterday. I have always had trouble with the gas cap on my FS90R trimmer. Many times it looks and feels like you have it on tight but then it will pop back off. I've got in the habit of always double-checking. Usually it takes several tries before I get it on right - but it's hard to tell when you have it on right and when it's not - you have to test it to be sure. It would be very easy for someone to think they had the gas cap secure only to have it pop off and spill gasoline while operating it. I thought the ethanol explanation was interesting. Mine has done this from the very beginning.
   / Stihl recall on some products for gas caps #12
I wish they would change the gas tanks and put good old screw on caps on them.
My older Stihl products work just fine and the caps always go back on right and tight
   / Stihl recall on some products for gas caps #13
There has ALWAYS been something wrong with some of the gas caps design. From day 1 my FS90R was IMPOSSIBLE to deal with. It doesn't come out after the cap is flipped up and it certainly took 5-6 tries to get it to seal right. My MS361 is the complete opposite. I LOVE the flippy caps on it. They work perfect and are much quicker and easier than carrying around the scrench all the time. I hope the recall makes my FS90R like my MS361!
ac
   / Stihl recall on some products for gas caps #14
FS90R trimmers tank cap:
Line up the dimple on the cap with the dimple on the tank, place the cap on, twist it to the right locking it down.
I got my new cap early last week. I never had a problem with my cap leaking but I have never ran ethanol gas in it.
   / Stihl recall on some products for gas caps #15
Just to make sure I wasn't nuts (wouldn't be the first time), I went out this morning to confirm. Following the exact procedure above - line up the dimples, turn right about a quarter turn (it won't go any further), it is seated, feels right - but when you push the flap down to lock in place it pushes the cap back up about a quarter inch and when you check, it is loose. If you are in a hurry and not paying attention, you might think you got it on and start using it. I did this over and over this morning with the same result. This is typical - it takes multiple tries before I can get it to lock down. As far as I know, I've never run ethanol in it - but I can't say I've paid that close attention to it. The station closest to us where I normally fill up the gas cans does not have ethanol in their gas but it is possible I filled up the tank somewhere else that did some time. Evidently, some caps had this problem and some didn't.
At any rate, I'm planning to go and get my replacement cap today - my SN is within the recall range. It'll be nice to not have to hassle with this anymore. It always kind of made me feel like an idiot - like, "can't you even figure out how to put a gas cap on":confused:
   / Stihl recall on some products for gas caps #16
I didn't know about the dimples until this spring when I bought a new chain saw. The dealer showed me. And I have been using Stihl products for a very long time.
   / Stihl recall on some products for gas caps #17
Might be different caps on chainsaws...........Chainsaws are not listed on the recall.
Yeah, I have a Stihl chainsaw and a string trimmer - they are different caps....My saw is older so maybe they switched the design before using the twist / flip down type on saws....
The funny part is, I noticed the exact problem they talk about in the racall notice, though I didn't know that was the case untill I read the notice when i got it last week and thought about how much trouble I had opening / closing the cap on my trimmer recently.
   / Stihl recall on some products for gas caps #18
I had noticed the cap coming off my pole pruner so when I got the recall I took it down. Just remembered I also have a blower that I suspect is covered by the recall as well. Looks like a second trip is necessary, maybe they will just give me a new gas cap?
   / Stihl recall on some products for gas caps #19
That's what they did for my string trimmer. I had it with me but they just gave me a cap. They asked if they could install it and I declined. I figured I'll run the old one for a while then change it out.
With my luck, I'll lose the new cap before I change it out.
   / Stihl recall on some products for gas caps #20
Yup, I just took the two old caps (one from my backpack and one from my Kombi) and they just swapped them out. I removed and reinstalled them on both units myself as it is very simple. You do not need to bring the whole unit but they do need the serial numbers. In my case I purchased both items from the local dealer so they had the serial number info on file. I also wondered about my chainsaws as the flip caps are pretty similar.
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
Electric Utility Cart (A56857)
Electric Utility...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2018 Peterbilt 567 T/A McNeilus 2511 25Yd Rear Loader Garbage Truck (A55973)
2018 Peterbilt 567...
Brush Cutter Mini Skid Steer Attachment (A56857)
Brush Cutter Mini...
