Thoughts on a 855
   / Thoughts on a 855 #1
Buckeye Chuck
Columbiana Ohio
Massey Ferguson GC2300 JD210 GT
Hi, looking around for my first tractor a guy down the road has a 1988 855 4wd with a 70a front loader, belly mower and back blade. It has truff tires that will need replaced, the bucket on the loader has some heavy rust inside of it and the steering seems to have some play with 1800 hrs on it. His asking price is 7.5K which I think is alittle too much. It also has some dings in the front and a chip out of the fiberglass hood. Any and all comments are welcome.
   / Thoughts on a 855 #2
That should be a metal hood on the 855. Plastic hoods didn't come around until the 4x00 series tractors.
The x55 series have held their prices quite well. Only you can determine if you want to pay the asking price. Obviously, offer less...but if the seller doesn't budge on his asking price (and you're not willing to pay) then you need to walk away.
Most buckets get rusty quickly...not a problem if it's just surface rust. Use a screwdriver to probe the rusted areas. I'm going to guess you'll find solid metal.
As far as the hours...1800 is high, no doubt. I doubt if you'd have any engine problems, but things like wheel bearings may be in need of replacement.
Only thing I've read (on TBN) negative about any of the x55 series Deeres is that parts are beginning to be harder to find. Outstanding tractors, otherwise.
Good luck!
   / Thoughts on a 855 #3
Actually the hood on x55 are plastic. The side panels and grill are separate metal pieces, but the tilt up hood is plastic. It is the only plastic piece on the tractor.
   / Thoughts on a 855 #4
I stand corrected!!! Surprised, but corrected!
   / Thoughts on a 855 #5
That's OK Roy. Interestingly when down the hood is latched into place with a magnet. They do that by gluing a thick piece of steel to the underside of the hood that lines up with a magnet mounted in front of the instrument panel.
I guess then the hoods on your 670 and 790 were metal?
   / Thoughts on a 855 #7
I've heard (but never checked) that the 33'' turf tires are hard to get also? Might be a little high for an early version. -fuel tank in front of the steering or the radiator
   / Thoughts on a 855 #9
I though the 55 hoods were fiberglass, as the hood on my 420 L&G of same vintage..:confused:
People here generally refer to anything that is not metal as plastic. That includes fiberglass, composite, or something else. The hood is fiberglass.
   / Thoughts on a 855 #10
I have found this to be true, and if you do find them they are not cheap. I've just kept my R4's on the rear during the summer as the turf tires are well worn and one of them leaks.
I very much like my 855 and consider it one of the best tools I have. I certainly use it more than just about anything. I need to have time where I don't need the tractor so I can perform some badly needed maintenance and repairs as I don't live where the tractor does so after work is out of the question.
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
Cat 60" Wheel Loader pallet Forks (A49461)
Cat 60" Wheel...
