Bolens 1468 won't shut off
   / Bolens 1468 won't shut off #11
Not sure if this will help you in anyway,but I have attached these pics for you to look at.I also have a 1468 and thought maybe the photos would help in some way.If you need any more pics I will get them for you.
In pic #2, the box with the yellow wires is the voltage regulator. The blue wire to the left of the regulator may be the kill wire. Does it have a disconnect/ plug at the top of the pic? the view of the ign sw shows rust/ corrosion. Check the plug that connects to the switch. Also, if you determine that the blue wire is the kill wire, with the ign sw off, you should read a dead short to ground from the kill wire.
jim
Hello guys!! Great news....it was one little wire that was disconnected! Jim, in your middle pic....it was the little blue wire that was unhooked!! I can not believe I missed it! This would have cost me a lot more time and money without you guys!! Thanks so very much guys!! Job well done! Happy fathers day all!!
Jack
   / Bolens 1468 won't shut off #13
Glad you solved the problem without spending any money.
   / Bolens 1468 won't shut off #14
Gotta love a quick fix.
Same problem happened to me twice.
Should add a different conncector, something which does not slide off so easily.
   / Bolens 1468 won't shut off #15
Jack
Good deal and congrats! Glad to be of assistance.:D:thumbsup:
Jim
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55302)
2019 New Holland...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
