Br780 baler has a belt that twists. Any solutions?
   / Br780 baler has a belt that twists. Any solutions? #1
Dedaisy
Member
MA
RTV-1120D, JD 5085M, Montana t7074, JD4300, JD4700, Kubota RTV900, JD 6x4 Gator, JD HX 2WD Gator, Terex HR16,JLG 40E Bloom lift
Belts generally appear to be good shape. The belt that twists is in the middle. I've reset it once and it lasted about 5 bales and flipped again. Tried reducing the core compression ( I.E. Hard core verses soft core) which reduces how tightly packed the bale is with no change with that belt. The belts general are looser when you do this. I'm thinking about replacing that belt and the one next to it ( the clipper on that one has a slight tear ). Any ideas? These belts are ~$200. The baler takes 8 belts..
   / Br780 baler has a belt that twists. Any solutions? #2
generally a belt flips over when the hay is to wet or a big pile of hay is forced in.i would get that belt relaced then set the pressure back up. you could also check the belt lengths ,your manual will tell you how long or short they should be.but you will have to take them all off.you could have a long belt.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
IH 1300 Sickle Bar Mower (A50515)
IH 1300 Sickle Bar...
2018 Toro 72in Zero Turn Commerical Mower (A50322)
2018 Toro 72in...
J & M 30' Head Cart (A50514)
J & M 30' Head...
