JD K series Commercial Walk-Behind Mower
   / JD K series Commercial Walk-Behind Mower #1
troubled terry
john deere K series Commercial Walk-Behind Mower GX1320X010939
Hello all, I am using a JD K series Commercial Walk-Behind Mower with a 48" deck on front and a one wheel "skate" on back. When mowing this morning the drive belt that goes to transmission came off. I have the mower on jack stands but can not see or feel how to get the belt on the trans pulley. there is a 4-5" pulley on a shaft going to trans, and a 2-3" pulley next to it. it feels as if the belt goes over top for big pulley but not the small one. there also seems to be a steel flat that attaches to the shift linkage in the way.
HELP! Terry
   / JD K series Commercial Walk-Behind Mower #2
i don't have this model wb, but you may want to check the jd parts website - it has photos of each part and how they go together. if you plan on keeping the mach for a long time and doing your own repairs (as well as maintenance) you may want to invest in a Technical Manual.
Thanks for the reply... I have manuals for everything I own, this is a friend of a friends machine, I like it, may try and buy it from him.
Is there a better forum for me to post this question in?
Have to hit the door, I'll check JD parts as soon as I return.
Thanks, Terry
2003 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2003 CATERPILLAR...
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
1995 BMW 318ic (A55758)
1995 BMW 318ic...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
