Welding bucket hooks - support plate warpage??
   / Welding bucket hooks - support plate warpage?? #1
Ruark
Mahindra 4025
It's pretty much a standard practice to weld bucket hooks onto a piece of 1/4" plate, then weld the plate onto the top of the FEL. I'm wondering, though: when you weld the hook to the piece of plate, doesn't it make the plate bend up from the heat distortion, so you can't lay it down flat on the FEL? Seems like it would...
   / Welding bucket hooks - support plate warpage?? #2
Clamp it in place. C-clamps should draw it tight. Dunno otherwise
   / Welding bucket hooks - support plate warpage?? #3
I have just welded hooks right to the bucket! Never had one brake or come off. Some I put on over 20+ years ago with no problems!
   / Welding bucket hooks - support plate warpage?? #4
Prebend the plate slightly away from the weld, when you weld the hooks on it'll pull back straight....Mike
   / Welding bucket hooks - support plate warpage?? #5
Putting a doubler plate under a hook is always a good idea. But don't stop there, make sure your doubler plate is round or oval, never use square corners!
Once you weld your hooks on the doubler plate, let it cool to the touch, turn it over, take your torch, and heat a circle the size of the weld zone on the opposite side. Take your garden hose and spray water on the heated area, (not on the hook side).
   / Welding bucket hooks - support plate warpage?? #6
I welded the plate to the bucket then welded the hook to the plate. Why not do it in that order?
   / Welding bucket hooks - support plate warpage?? #8
Wombat, those are some good looking welds on your thread...
Ian
   / Welding bucket hooks - support plate warpage?? #9
Here's a picture of mine.
   / Welding bucket hooks - support plate warpage?? #10
I welded 1/4 inch on the bucket, but used a large tow hook and bolted it to the metal, that way if ever i needed or wanted it off i could.
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A51247)
UNUSED CFG...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
UNUSED X-STAR 70" QUICK ATTACH MANURE/SNOW PUSHER (A51247)
UNUSED X-STAR 70"...
40' CONTAINER (A51248)
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
