Finish mower with bush hog blades: Such a thing?
   / Finish mower with bush hog blades: Such a thing? #1
beppington
Elite Member
of my
Here
Don't own one, but I've read that pro grade zero turn mowers have pretty thick mower decks.
Just wondering if it would be reasonable for somebody to make a "bush hog blade option" for heavier duty finish mowers? (assuming it's not already available)
The idea would be, when you want to bush hog instead of finish mowing, you'd remove your regular finish cut blades & install maybe a small stump jumper with blades swinging on their own spindles, like typical rotary cutter blades.
Is this already available?
Any reason it couldn't be done?
   / Finish mower with bush hog blades: Such a thing? #2
The Woods RM990 comes pretty close with free-swinging blades giving a finish quality cut.
I'm talking about doing this on a zero turn or other dedicated mowing machine (riding lawn mower), not on a tractor implement.
   / Finish mower with bush hog blades: Such a thing? #4
If you turn a lawn mower into a brush hog, the next transformation will be turning it into scrap.
What parts on a big, heavy pro-grade zero turn mower would fail?
   / Finish mower with bush hog blades: Such a thing? #6
Drive belts, any pneumatic tires, blade spindles, and the deck shell, probably in that order. None of which are designed to handle the loads of cutting stiff, brushy stems or driving over sharp stumps.
   / Finish mower with bush hog blades: Such a thing? #7
You also don't have the horsepower for brush mowing. Note that a tractor rated for a 4' brush mower will be rated for a 5' finish mower. Take something designed for a finish mower, it won't handle the same size brush mower.
The HP-per-foot criteria can actually be met: Kubota's zero-turn ZD221 has 21 HP & is available with a 48" mower.
But ... I had in mind not your typical bruiser style bush hogging, where you jam the bush hog into whatever mess you encounter as long as there doesn't seem to be woody stuff any bigger than what your hog can handle - I had in mind lighter usage, cutting stuff somewhat bigger than what you'd normally cut with a finish mower, but not as big as what a tractor's 3PH bush hog can handle.
   / Finish mower with bush hog blades: Such a thing? #9
I don't know of anything like that being available at this time, and I don't know whether it could be made and be practical, but I like the idea. And ideas and dreams are how things get invented.:)
   / Finish mower with bush hog blades: Such a thing? #10
Not all of that horsepower on a zero turn goes into cutting.
Realize that something like a ZD221 has three blades across (as do most finish mowers). There isn't enough room front to back for a brush mower bigger than 24" or so unless you go to a multispindle design like a batwing bushhog ($$$$$). Note that bush hog type cutters are always rear mount, I've never seen a mid mount type. I think that has to do with the size and sturdiness required.
If you really do not expect to get into cutting big stuff or running into rocks, then you can do it with a finish mower. As long as you aren't hitting anything that won't give, the big limitation of a finish mower is the discharge area clogging up. Opening up the discharge area would solve that. I've used finish mowers and a ZD221 for mowing pasture paths, the limitation is usually the side discharge clogging up. Yes, I did bog down the ZD221, but then I also bogged down a M9540 (90 hp) with a 15' batwing in the same area!
Ken
500 BBL FRAC TANK (A53843)
500 BBL FRAC TANK...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
Caterpillar Loader Quick Coupler (A55218)
Caterpillar Loader...
