Questions to ask a welder before fabrication begins
   / Questions to ask a welder before fabrication begins #1
nickel plate
CA
2002 New Holland TC40S
I have designed a shotgun scabbard holder for my tractor and am now looking for a local welder to stick it together. The job will have 32 welds 2" long and 9 welds 3" long. The materials to be welded are 1/4"x1", 1/4"x2" and 3/8"x3" mild flat steel. Visualize a birdcage type of construction 26" tall and 5" wide that a synthetic scabbard slides into and bolts to the tractor. For the final finish I'm thinking powder coat or?
1. What type of welding tool should be used assuming all welded areas are of easy access?
2. What type of wire or rod should be used?
3. Anything else that I need to know to ask the welder?
Thanks
   / Questions to ask a welder before fabrication begins #2
Good rule of thumb, never tell a man how to do is job. Just tell him what you want.;)
I personally would Mig weld it.
   / Questions to ask a welder before fabrication begins #3
agreed, remember he is the welder, not you. He will know for sure how to do it, so just let him do it.
Thanks guys but I'm not in the habit of telling an expert anything, I'm asking you what should or not be used.
   / Questions to ask a welder before fabrication begins #5
I would probably use a stick welder with a 6011 or 7014, based on the thickness (and the fact I only have a buzz box and a cutting torch) a MIG would also work very well.
   / Questions to ask a welder before fabrication begins #6
You gotta remember if you go to a pro, it's all about money to him, time is money. He's going to do it the fastest way possible. I'll bet cha it's Mig .035, ER70S-6 ;)
   / Questions to ask a welder before fabrication begins #7
if you have a tractor, and a gun, then you should know how do your own welding.:thumbsup:
   / Questions to ask a welder before fabrication begins #8
You can buy a smaller tig stick unit for what it will cost to have it welded and you get to keep the welder. Cool 1st project for You and you can say You made it. It will be very easy once you get started.
Do it.
:thumbsup:
   / Questions to ask a welder before fabrication begins #9
I have gone to my friend's shop to make something. He was out of stock of the materials I wanted to use. When I go back the thing is made better than I would have done it. I have also gone to his shop, cut and welded all day. Stuff I made worked fine. Anytime I get something tricky I cannot do at home with my Hobart Handler 140 I go to visit his shop. He has much bigger and better tools and the experience than I ever want to have.
   / Questions to ask a welder before fabrication begins #10
i would weld it with that handler. it should be plenty for a gun holder.just at first ,do not try it out bush hogging.
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
2015 CHEVROLET CAPRICE POLICE CAR (A51222)
2015 CHEVROLET...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52128)
2015 Ottawa Yard...
INSPECTION (A51572)
INSPECTION (A51572)
