m/f 165, 3pt stabalizers
   / m/f 165, 3pt stabalizers #1
Joe Blackeby
Member
west jersey, exit #5 turnpike
allis D-14's, massy 165
Howdy, seems of the three 165 i know of all three have only one working and one broke off. Was this a "weak link" in the system. Is there a left and right, these are bolted to the axle under where the fender mounts???
Gonna try to attach pics????
   / m/f 165, 3pt stabalizers #2
Weak link? Not hardly. Where they got snapped off was most likely when someone tried using ONE stabilizer in a situation where there should have been TWO in use. (one each side)
I have my dads old Ferguson F40 (early 1957) and my uncles MF50 (late 1957) out behind the barn. BOTH had the original cast style brackets, and neither have broken. They served faithfully for more than 50 years. I'd suggest the newer style that are made from 3" X 3" angle iron. You'll find them (among other places) at TSC. Those are the type I have on my 150.
Thanks Farmwithjunk, i'll see what they have @ TSC. Were these the same point that the loaders attached to? Seems if i cleaned off the drill press i could fab something with angle-iron. Again, Thank You!
   / m/f 165, 3pt stabalizers #4
I've seen several loaders on Massey's that attached at the same points. They did NOT use those brackets as mounting points though. (Used 2 bolts through fender brackets)
The angle iron brackets would be a piece of cake to fabricate yourself. I'd slot the 2 holes where the fender bolts pass through to allow some adjustment. Pins would mount in line with lower link mounting points.
If you need a photo, let me know.
   / m/f 165, 3pt stabalizers #5
Hello
I am trying to get part numbers for our MT 275B Challenger Tractor for Fuel Filter and oil filter, anyone got info? please call or email.. Thank you so much
985-400-3486
moreesdozerservice@ymail.com
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2016 STOUGHTON 53FT DRY VAN (A57880)
2016 STOUGHTON...
2020 DRAGON ESP...
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
