How to recognize manufactured home axles?
   / How to recognize manufactured home axles? #1
RidgeHiker
Gold Member
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
We are looking for a used dual axle flatbed trailer to haul our tractor. If a trailer does not have obvious branding on it (from a commercial manufacturer) how do we tell if the axles are from a manufactured home? :confused3:
   / How to recognize manufactured home axles? #3
But some legit non mobile home wheels look the same...
I'd look at the axles, if they have a splice in the middle they were 99.999% certainly shortened mh axles.
What do you mean "a splice in the middle"?
Is the axle 2 parts welded in the middle???
   / How to recognize manufactured home axles? #6
i don't think there is an easy way to positively identify all axles that came from mobile homes.
the obvious way to start narrowing down the field is the hub/wheel setup. as was mentioned look for wheels with no centers that clamp to the brake drum/hub (all the ones i have seen use five clamps). the wheels are 14.5" diameter also. this isn't a determining factor though, because there have been plenty of commercial trailer axles made with this size wheel and hub style.
some mobile home axles do not have complete backing plates. the ones i have use a backer that does not completely cover the inside of the drum. it is just large enough to attach the brake shoes and the magnet. again, this is not indicative of all mobile home axles. there have been some people here who have said they have mobile home axles with complete backing plates.
there has also been some discussion recently where people have posted excerpts from an axle site saying that their mobile home axles do not have precision machined spindles. i'm not completely sure of the exact meaning of this, but i'm wondering if it just means that the spindle forgings are only machined where the bearings go? no matter what, it would require a bit of disassembly to figure out. plus, i'd be willing to bet that any difference you might see are localized to only certain brands, and that you will find some mobile home axles that are indistinguishable from commercial axles.
   / How to recognize manufactured home axles? #7
It is tough to tell the differences if you don't know what to look for and without doing some disassembly. I'd look for a manufacturers ID tag on the axle first. There's no reason to remove such a tag, (usually riveted or spot-welded in place), unless the trailer builder does so on purpose...and why would they do that? The splicing is a dead giveaway, but lots of folks around here use MH axles without cutting them to a "legal" length. Trailers are typically limited to a 102" overall width according to regulations, and I've had lots of conversations with customers over the years that tell me they won't need to rent a trailer when picking up a piece of equipment because they have one of their own. When asked what type/size trailer they have, they're not shy about disclosing the dimensions. Many with un-cut MH axles are 104", (or a little more), in overall width. Years ago, I built a three-axle trailer for a guy that had MH axles and insisted using them. He didn't want them shortened up, so I used them as-is. I told him that after I was done he would have to have the trailer inspected by a highway patrolman that would need to sign off on the trailer's construction and road-worthiness before issuing a VIN. I said that since the 102" max width was on the books, I was sure the trailer would be measured. The owner thought it was worth risking and he lucked out because the officer never broke out the tape measure. To the outside edge of the tires, this trailer measured 104 1/4" inches wide.
My *opinion* would to be very suspicious of any trailer lacking a manufacturers' VIN or ID tag. Why? Simple....there are "good" axles that employ the rim-clamp style hubs and use the 14.5 tires. We have a couple of Dyna Weld trailers that are set up that way. But those axles that are serviceable and do not have the 'limited-use" designation MH axles have are expensive to purchase. I'd say it's likely they cost the trailer manufacturer as much as more traditional "service type" trailer axles used by most manufacturers. In other words, if a DIY-er is building an equipment trailer, he very likely either used MH axles...or....he coughed up the $$ it took to buy a set of higher-quality non-MH axles like the Dyna Weld trailers use....which makes no sense at all given the additional compromises he'd wind up with by having to run the 14.5 tires.
MH axles are chosen most often by DIY-ers because they're cheap and easy to find.
If the builder claims his rim-clamp style axles are not MH axles, I'd ask for a receipt for the axle(s) he purchased....and if he couldn't produce a receipt, I'd ask where they were purchased from. A couple of specific questions is all it usually takes in order to weed out the BS-ers.
   / How to recognize manufactured home axles? #8
Also, check the tires, most people who use a mobile home axle to build a cheap trailer would not have bothered to replace the tires with legit 14.5" tires, so the tires will say something to the effect of "single use only" or "MH use only" on the sidewall.
   / How to recognize manufactured home axles? #9
Here are the axles used for my doublewide delivery in Sep05
   / How to recognize manufactured home axles? #10
Many other threads mention MH axles having the brake backing plate welded to the axle instead of bolted to a flange.
Bruce
New/Unused Quick Attach Pallet Forks (A48837)
New/Unused Quick...
2019 HINO 268 26FT NON CDL BOX TRUCK (A50046)
2019 HINO 268 26FT...
2024 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2024 Ford F-150...
2017 CATERPILLAR 938M WHEEL LOADER (A50458)
2017 CATERPILLAR...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2001 HEIL PNEUMATIC CEMENT TRAILER (A50046)
2001 HEIL...
