3-Point Hitch Cracked metal hydraulic line
   / Cracked metal hydraulic line #1
nightnurse
Kubota B2400
I have a 15 year old Kubota B2400 HST, with a crack in the metal hydraulic line to the 3 point lift arms. Can this metal line be replaced with high-pressure rubber hose, and if so, what pressure rating should I use?
   / Cracked metal hydraulic line #2
Not sure about your Kubota, but most tractors run 2750 PSI or higher. Check with a local dealer, they may be able to replace or reccomend someone that can repair or make a new line. New line can be flexible and that is OK.
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
1992 SYLVAN 20' PONTOON BOAT (A51247)
1992 SYLVAN 20'...
UNUSED WOLVERINE PFF3-13-45W UNIVERSAL MAST (A51248)
UNUSED WOLVERINE...
2017 HINO BOX TRUCK (A53426)
2017 HINO BOX...
2003 JOHN DEERE 350D OFF ROAD DUMP TRUCK (A51246)
2003 JOHN DEERE...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
