Sporadic Hydraulic Leak on TZ18
   / Sporadic Hydraulic Leak on TZ18 #1
Rich C
I have a TZ 18 with 400 Hrs on it which equipped with front loader & backhoe. Also have a belly deck on it. I can run the machine with the mower going in a stationary position [meaning not cutting grass] & there's no hydraulic leaking.
Once I'm cutting, I find fluid coating the rear chasis but can't determine the source of the leak.
I did find the lower filter loose a few weeks back & tightened it and the problem seemed to had gone away. But then began again. My guess is I may have overtightened the filter and compressed the gasket to the point where the fluid would spray thru once pressure & heat maxed while cutting. Thing is, the leak is literally not visible. Checked all bolts on the housings, connections & hoses and they're dry.
I just changed both Hydraulic filters but now am waiting for grass to grow to be able to cut with a load. In the meanwhile, anyone have any ideas what can cause the problem?
   / Sporadic Hydraulic Leak on TZ18 #2
When you raise the mower deck does it make contact with the hydraulic filter? You may need to adjust the up stop gap on the mower.
Nope Jim...there's clearance.
City of Buckhannon - 2000 Chevy 2500 (A52384)
City of Buckhannon...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2021 John Deere 410L Backhoe (A53342)
2021 John Deere...
