New Idea fertilizer spreader
   / New Idea fertilizer spreader #1
MMagis
Guernsey Co. Ohio
Ford 3000, JD 2550
I acquired an older New Idea fertilizer spreader, and have a question for anyone who might be familiar with it, or one like it. It looks just like this one. I forget the model number, but I'm guessing it's the 116. My question is the gear box and how to fill/change the fluid. There really isn't any obvious drain or fill plug. The closest thing I can find is over an inch from the bottom, and obviously that leaves a lot of fluid and all the "bad" stuff. I can tip and get most of it out, but how do I fill it? Do I just fill it to the level of that hole? The spreader is so large it's a bit difficult to maneuver around, but that's the only was I can figure out it's supposed to be done.
   / New Idea fertilizer spreader #2
My hunt club acquired a spreader that just has a single spreader plate (not a "dual" set up like yours) and the gear box had no drain or fill plug either. Not knowing if it had any oil in it, we wound up drilling a hole into the gear box near the top, tapped it, and put in a grease fitting. As it turned out, it was full of oil so we now at least have a way to put oil into it if needed. You may have to do the same thing. Just don't understand why they would not put in a drain and fill plug??? Maybe they consider it not worth fixing if it does go bad and just want you to buy a new one???
I couldn't understand it either. I thought maybe I was missing something obvious, but I don't think so. I don't suppose it needs changed often, but this one has been sitting out for a while and has one bad top seal, so some water got into the gear box. For the $45 I paid for the thing, I can afford to drill and tap a hole or two if that's what it takes. :D Thanks.
1 pallet of Brake Chambers (A53117)
1 pallet of Brake...
1998 Jeep Cherokee Sport (A50123)
1998 Jeep Cherokee...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2016 Suzuki King Quad 500AXI 4x4 ATV (A51694)
2016 Suzuki King...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
