New Holland TN75
   / New Holland TN75 #1
Ron Manes
New Holland TN75
I was loading hay with my tractor the front end loader and rear lift stopped working. Could the hydraulic pump be out on it? Cause it just stopped working all of a sudden.
   / New Holland TN75 #2
If it has a joystick, make sure that the valve is working properly. It's cable operated and i think there is a priority system that doesnot allow the three point to work when the lader valve is operated. Someone like RickB or JVBrink64 can provide a lot more help than I can. Repost with their names in the title.
   / New Holland TN75 #3
had this happen.
locked in position? (not up or down?)
one of the connectors slipped out (esp if it's got mid-valves and they are down low and get hit). it will look like it's in, but it's not.
pull on all 4 connectors and make sure they are really in there.
you'll have to release all the pressure on it before you can get it to hook back up
   / New Holland TN75 #4
I also had this type of issue. Got air in the hydraulics some how and once I bleed the hydraulics everything worked as normal. I thought I lost a pump and after calling my dealer and following their recommendations I was good to go.
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
2013 Kubota RTV-X900 4x4 Diesel Utility Cart (A55787)
2013 Kubota...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
