Is a 60 box blade too big for a 26 hp tractor?
   / Is a 60 box blade too big for a 26 hp tractor? #11
For my use the important thing is that the BB is wider than my tractor track. Let's me work along an obstacle without running my rear tire against it. You can always lift the BB or raise a tooth or two if you can't pull it. But you can't add width.
   / Is a 60 box blade too big for a 26 hp tractor? #12
...But the OP is asking about a 5 footer = 60" (as in the title)... correct? ;)
Duh, on me.
Wake up little Suzie.!!
YES, a 60" box blade is a good fit for your tractor.!!:p:confused2::thumbsup:
My tractor is about 48" wide.
I pulled the trigger today, picking up a 60" box blade. I went the economy route, choosing the Countywide at TSC. It's definitely lighter built than the Landpride BB I had been borrowing, and the scarifiers don't extend as deep, but I dragged it around today and managed to flip some good rocks in my daughter's driveway. Seems like it'll do the job.
Thanks for all of your advice. Mike
   / Is a 60 box blade too big for a 26 hp tractor? #14
Congrats! Pics, please! We all like pics! :cool::D:thumbsup:
Joe
Thanks for the reminder. I'll post some pics soon.
   / Is a 60 box blade too big for a 26 hp tractor? #16
I've got a chance to buy a 60" box blade. My tractor is a Kubota B2620 (26 hp) with loaded ag tires. Is this implement too big?
I recently borrowed a 48" BB which worked great, but I can't continue to take advantage of my friend's generosity with an implement that I find so useful that I might never run out of jobs for it.
I run a 66" box blade behind my bx2660 and it works like a champ! I have loaded turf tires. Get after it!:thumbsup:
   / Is a 60 box blade too big for a 26 hp tractor? #17
Decent. I have a few CountyLine attachments that have performed flawlessly.
Take it slow and easy and you will get years of good use.:thumbsup:
   / Is a 60 box blade too big for a 26 hp tractor? #18
Keep us posted...... I have a B2620 too, and currently use a Woods 48" BB. In my rocks, and when the clay is wet it pulls it along with all four just churning in slow motion, but not really much faster than I am moving. :D That extra foot in width would be handy lots of times, but I was afraid it would be too much. Now my neighbor has a Massey 1528 which is only two hp more, but 1000 lbs. heavier, and I wouldn't even give it a second thought with that tractor. Weight is our friend when pulling, or pushing.
   / Is a 60 box blade too big for a 26 hp tractor? #19
in general, it's probably ok. An N is about that hp and uses a 5' box.
soundguy
   / Is a 60 box blade too big for a 26 hp tractor? #20
I have the 48" land pride box blade. Don't know how well it would pull a larger one, but the 48 covers the tracks, and should be able to get up next to something. use it all the time. The dealer says that is the "factory" BB for that tractor. I bought it from the dealer shortly after I bought the tractor. Basically asked him for the recommended BB, because I was needing to flatten out some dirt.
One thing I noticed is that weight is very important for getting them to dig. If I were to get a larger blade, and the weight didn't significantly increase ,it may not work right. If the BB were that heavy, it may be too heavy without counter weights on the front.
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2011 Ford Edge AWD SUV (A55758)
2011 Ford Edge AWD...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
