New type of aerator...thoughts?
   / New type of aerator...thoughts? #1
AlanP
Hi, new to the forum - glad to have found a forum with lots of like-minded tractor enthusiasts! :thumbsup: Wanted to post a question about an aerator I found on ebay (think auction has ended by now), but wanted to know if any of you have heard about this kind of aerator and/or seen a similar one. I own/run a small lawn care business and am looking to get a better, more efficient, aerating setup. Looks like this particular one would take care of a lot of the things I currently dislike about aerating (looks like their optional lift cylinder would eliminate having to manually lift/lower the unit to cross sidewalks/driveways, their unit can maneuver unit around curves/turn while in the ground, etc.).
I also used to have a walk behind and have since sold that. While it was convenient for small yards, it would still take longer than I thought necessary and is much harder on the body (nothing like using a walk behind to realize how old you're getting!) :laughing:
Am wondering if this unit might be a better solution than my current basic pull behind aerator set up (would set up, or order their optional sleeve hitch) and since it looks like it can get/back up into tight spaces, I wouldn't have to mess with any more walk behinds. :D
Would like to get a better set up in place before the fall rush hits - any thoughts and/or input you guys have would be much appreciated! Alan
Aerator on ebay...
36" Core Plug Lawn Turf Aerator Sleeve Hitch -towbehind | eBay
   / New type of aerator...thoughts? #2
This aerator from PT is 48 in, and cost $1600.
Someone on TBN made their own by using a round tank and welding on plugger/spikes.
Should only cost about $300 or less.
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2019 Grove TMS500-2 40 Ton Hydraulic Truck Crane (A60460)
2019 Grove...
2008 KOMATSU D51PX-22 CRAWLER DOZER (A60429)
2008 KOMATSU...
2019 Grove TMS 9000-2 115 Ton Hydraulic Truck Crane (A60460)
2019 Grove TMS...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A60460)
2013 Ford F-250...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
