Finally got me a REAL Truck
   / Finally got me a REAL Truck #11
Nice. Make sure they replace the u-joint with one that has a grease fitting on it.
   / Finally got me a REAL Truck #13
LD,
Nice score :thumbsup:
Which tranny is in it - automatic or manual ?
Thanks for all the compliments:D
It is an auto tranny.
And the joints in there now definatally arent greasable. And its kinda funny, because the last few times I have done u-joints, the lifetime warrenty ones arent greasable, and the 1 or 2 year warrenty ones are:confused:
I have also heard that the NON-greasable ones are supposed to be stronger??? Allthough I have NEVER actually broken a u-joint. All of the ones I have EVER replaced have been due to lack of grease. I did the rear one in my silverado @ about 90k miles. Dry as a bone inside and NO fitting.
And as to that alarm, I was wondering what that was. It seems like sometimes it would go off, and others it wouldnt. But I do have a habit of leaving the door open when I am backing up to the trailer to hook it up. That way I can see the ground and gives me a better visual when I know I only need to back up like another 8" or so. That is harder to judge with the door closed.
   / Finally got me a REAL Truck #15
Sexy truck man! I am envious.
I have a regular Ram 1500, it's an '03 and I have nearly worked it to death. I have replaced both U joints by 200,000 kilometres and put greasable ones in. I think the first one went (the rear) at 150,000 k's which is about 90k miles.
Good luck though, that's a real man's truck!!!! :thumbsup:
   / Finally got me a REAL Truck #16
d.
Non greasable joints are stronger as their centers are solid and not drilled through for zerk fittings. They are for people who do not grease their ujoints regularly which is most people and will last longer than a greasable joint that isn't greased. They get troublesome when submersed in water so they are not for every application.
   / Finally got me a REAL Truck #17
Looks like a nice truck. I would take a 5.9L over a 6.7L any day.
Check your ball joints for vertical play. They have a poor design where the lower joint supports all the load and the upper one acts as a free-floating king pin.
   / Finally got me a REAL Truck #18
how ya like it?
i looked at a 00 3500 today.. v10 gasser i think
soundguy
how ya like it?
soundguy
I really like it so far. But I havent had a load behind it yet.
A 2000 v10 gasser would be apples to oranges compaired to this. I was only looking at 03 and newer to get the newer body style:thumbsup: And was really not wanting anything newer than 07 to stay with the 5.9L
   / Finally got me a REAL Truck #20
Just as an aside...
My mechanic put in a splicer u-joint on my F350 that is a grease-able u-joint...
I like it better and I would think that you would too...
You're gonna really like that Cummins...
One tough puller...
Giyi Excavator Attachment Set (A57149)
Giyi Excavator...
2007 Volvo VNL Truck Tractor (A56436)
2007 Volvo VNL...
2838 (A58376)
2838 (A58376)
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
2022 Diamond T 14' Dump Trailer, VIN: 5FWDS1423NR030358, Tandem Axle, 7 Gage Steel Floor, Power (A59076)
2022 Diamond T 14'...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
