Looking for 3-point adapter for Loader
   / Looking for 3-point adapter for Loader #1
TGF
Gold Member
Blair, NE
3038E
I have searched the site and found several of the opposite of what I want, adapters that let loader accessories be used with the 3-point. I am actually looking for something I can put on my loader arms that allows me to pick up and manipulate 3 point attachments to assist with maintenance jobs and storage. I have a JD 300 series loader, so it would need to be a JD QT to 3-point or iMatch would be really convenient.
Something like this only for JD.
HORST WELDING | HLA >> THREE POINT HITCH ADAPTER
no body?
   / Looking for 3-point adapter for Loader #5
I built something similar... made HF quick hitch.
   / Looking for 3-point adapter for Loader #7
Couldn't you just weld a jd quick connect plate to a imatch and use that?
Where have you found setups to put a fel quick connect on the 3pt arms. I have been looking for something like that but have had no luck and figured I would have to make something when I had time.
   / Looking for 3-point adapter for Loader #8
My approach was a little different since I wanted the same side tilt
capability you have with a rear 3PH. I welded up a 3PH with arms
and links that fits on my pallet fork frame.
Here is my rake, which I can adjust for side tilt. I also fit a pole inside
the rake frame after removing the rake, and have a front-mounted
boom pole.
Sadly I can't weld for beans, so it looks like what I am going to do is go down to TSC and buy a 3-point QC and a hitch reciever, hit the JD dealership buy a set of loader connects, then go to a local welder and have him put it all together for me. Thanks for the help guys.
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
1991 Mack RW713 Day Cab Truck, VIN # 1M1AY10Y4MM005693 (A51572)
1991 Mack RW713...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53472)
2003 International...
Kubota BX2230D (A47384)
Kubota BX2230D...
John Deere X530 (A51573)
John Deere X530...
