Flail Mower 48-inch Mott blown cutter shaft bearing
   / 48-inch Mott blown cutter shaft bearing #1
fesjwra
JD850
Hello all,
New to the site, I'm revitalizing an old pioneer farm with
a JD850 4X Yanmar diesel, 24 HP, and a range of attachments. Just blew the right-side knife shaft bearing on my Mott 48-inch rear PTO mounted hammer knife mower, and I'm feeling almost as blue as the race it ejected, 'cause I don't know where to get another one, the whole bearing assembly that is. Alamo doesn't list a part number for my model.
Any suggestions from Mott owners?
Cheers and thanks,
John
   / 48-inch Mott blown cutter shaft bearing #2
Try flailmaster.com
   / 48-inch Mott blown cutter shaft bearing #3
Welcome to the Forum,
You can obtain the bearings from flailmaster as long as the numbers on the bearing inner and outer races are still legible. You should also plan on changing the V-belts with the kevlar stranded belts from TSC or NAPA as well.They are very good belts which stand up to shock loading from flailmowers.
Please keep in mind that you should grease the bearings every 4 hours of continuous use or daily depending upon your seat time used.
You also need to check the rotor for any material that is wrapped around it and near the bearings as it will create heat sink and quickly melt grease in the bearings. Just be sure to have plenty of clean wash water and Fels Naptha handy to wash your hands and arms in case of poison ivy, oak or sumak. The blue nitrile gloves are also very handy to have when diigging around a lot of debris and chaff under a flail mower.
As of today you have entered and become one more important member of a group of mower owners which is
"The Flail Mower Nation" which are a fun bunch bunch of mower owners that like our mowers and always have time to chat or provide members with advice, experience,before and after pictures of mowing with our use of flail mowers (I still have to post a picture of our Mathews Lawn Genie but I have not done so yet).
"Once You Go Flail you Never Go Back"
Many thanks leonz! I very much appreciate your voice of experience in this! I'll be contacting flailmaster tomorrow.
Again, much obliged,
John
   / 48-inch Mott blown cutter shaft bearing #6
Does your 48" Mott look like this?
MOTT K48 Hay and Forage Equipment - Stalk Choppers/Flail Mowers For Sale At TractorHouse.com
Yes, thanks! this the mower I own.
John
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
2004 Ferrara Pumper Fire Truck (A51692)
2004 Ferrara...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2013 Caterpillar 950K Articulated Wheel Loader (A51691)
2013 Caterpillar...
SN:240402641 (A51694)
UNUSED 72" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED 72" HYD...
