middle buster use
   / middle buster use #21
Is your draft control adjusted correctly. It will raise the plow as the load increases on the draft control. Set the draft control to it's lowest, or most loaded level.
   / middle buster use #23
OK guys, I need someone to tell me what I'm doing wrong with my middle buster.
I just purchased a middle buster from TS to use on my Kubota B7500 (21 hsp) to turn over some ground that I just mowed, prior to disking and planting for food plots. I am working in some old fields that don't really have sod persay, but do get mowed with a brushhog yearly.
When I drop the middle buster and start going forward, I can't get it to really "grab" and stay down in the soil. It just keeps popping out on top of the ground after a few feet. I tried an aggressive angle (with the top hitch on my tractor shortened up as much as possible and the one that I was certain would make it really dig in), a straight vertical angle, and a less aggresive angle. What gives???
Thanks.
Teach
Here are a few photos of the TSC middle buster on my 2005 Kubota B7510HST
The soil is fairly soft with a lot of gravel mixed in.
   / middle buster use #24
   / middle buster use #25
I agree with post number 18.
Check the middle buster to make sure it was welded together right. Maybe they welded the bottom pieces on for a subsoiler instead of the middle buster. The bottom of these two are different.
I have the same one as you and have only used it once but I just hooked it up, adjusted nothing and it worked fine.
   / middle buster use #26
   / middle buster use #27
Your first photo appears to have the plow blade attached bottom side up, or is that just an illusion? The last two photos shows the blade attached correctly.
Must be an illusion--I don't recall installing that blade backwards. Anyway, the MB works fine in my soil with the blade installed correctly. I never had a problem with the plow popping out of the ground.
   / middle buster use #28
View attachment 173907View attachment 173908View attachment 173909View attachment 173910
Note how the top link is adjusted longer in the photo. The key would be for the bottom edge of the blade to be adjusted to run flat or slightly at a downward angle.
My middle busters are homemade so adjustments are different but looking at the bottom of the blade should show how to get it to bury itself.
   / middle buster use #29
I know this is an older thread just wanted to say that I bought a middle buster from tractor supply it came with the shovel upside down. It took me a day to figure this out. I still can not get it to dig deeper though -- often it just skips along the top. Considering getting a shorter top link, what do you think?
   / middle buster use #30
How deep it goes depends on a couple of factors, but yes, if your top link is too long and holds the tool in a way that doesn't encourage the spade to go deep, then start with that. I like vertical, but our soil is soft and sandy. With harder soils, you'll need to pitch it a bit and try it. It's experimenting, but it works.
This time of year is tough most places, as the soil is getting sun baked and very hard.
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
2016 Hyundai Tucson (A55758)
2016 Hyundai...
CASE TR310 SKID STEER (A52705)
CASE TR310 SKID...
BUNDLE OF APPROX 9 10" I BEAMS UP TO17' (A54756)
BUNDLE OF APPROX 9...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
