Information Conflict from Tennessee
   / Information Conflict from Tennessee #1
Uncle Wayne
Moulton, Alabama (Lawrence County)
4320 John Deere
I've been shopping around for a older John Deere, (especially a LA), Ford 3000 or a Farmall Cub tractor. I have reason for wanting each and have found several in Tennessee. Thinking ahead, I called the Tennessee Highway Patrol office and told them: I'm looking at buying a tractor in Tennessee and wanted to find out the requirements for hauling a tractor on a flat bed trailer back to Alabama.
Here's what the state trooper office said: Just secure it to the trailer so there no forward or backward motion while being towed.
I asked: There's no requirement that I need one tie down per corner?
He said: No, just make sure it's secured to the trailer.
I asked: can I used the appropriate size ratchet type web straps, one on each end?
He replied: Yes, if that secures it to the trailer. As long as you have the trailer registered in Alabama, you'll be all right in Tennessee.
Well almost all of that contradicted what I thought was right so I called the Tennessee DOT and made the same statement: I'm looking at buying a tractor in Tennessee and wanted to find out the requirements for hauling a tractor on a flat bed trailer back to Alabama.
DOT reply: You're required to use a chain on each corner, that will be 4 per tractor. Any piece of equipment laying on the trailer, plows, etc will require two chains.
I asked: can I use the ratchet type web straps in place of chains?
DOT reply: No, only chains rated for the load are permitted. And each tie down point requires a separate chain. A long continuous chain tying down one side and extending across to the other side is not permitted.
I said: That's completely different than what the State Trooper office told me.
DOT reply: (Laughing) yeah, you're not the first one to tell me that. They don't know anything about transportation requirements and would not inspect your trailer unless you were involved in an accident or a moving violation. Our department will be notified if a trailer is involved and we'll make the appropriate decisions once they contact us.
I'm glad I called because I had intended to use my ratchet straps. I will now have to buy chains and binders / booms instead.
   / Information Conflict from Tennessee #2
You want the chains for sure. I have seen quick jerks snap decent size nylon straps. The DOT told me, anything over 10,000lbs needs 1 chain at each corner (2 smalls not 1 long as you said) plus 1 chain per bucket. They didn't comment under 10,000lbs. I guess there is a wide variance from state to state.
   / Information Conflict from Tennessee #3
I don't think it's ever a good idea to *ask* anyone questions like this. You'll get a variety of answers...and most of them will be incorrect, or partially correct, or....
The best source of info is your state's DOT website. Not only will regs be clearly spelled out, but you can also print a page or two and take 'em with you. If there's a problem along the way, having a copy will go a long way towards showing the authorities you made an effort to be in compliance.
The other benefit of going to the DOT site is that the information is updated as regulations change. What someone tells you is okay, may have been okay years ago...not necessarily any more.
A couple of years ago, I watched in amazement as three or four other employees spent half a day talking to each other about, (and calling others to ask as well), what we needed to do to be in compliance because we purchased another hydraulic tail equipment trailer that was located two states away. In the end there was a lot of time wasted on the discussion, and no real useful information exchanged or conclusions drawn because all of the opinions were preceded by things like, "As far as I know", or, "According to a truck driver friend of mine". In other words, it was about as productive as your typical meeting usually is.
   / Information Conflict from Tennessee #4
I agree with chains on the tractor but chains on the equipment lying on the trailer such as a plow, etc... is a little overkill. The attachments would be fine with straps. I use chains on the tractor and straps over the loader and backhoe to keep them from bouncing around.
   / Information Conflict from Tennessee #5
Sounds like the state gave you the rules for equipment > 10,000 lbs.
When you get into CDL weight ranges there are very specific rules on how things get anchored to the trailer. Non-cdl it just needs to be 'secure'.
   / Information Conflict from Tennessee #6
In theory this is a great Idea, in practice it did not work for me. I don't know about other States, but I live in the peoples republic of New York. The DOT web site is so confusing, and unorganized that you cannot make hide nor hair out of anything. My mother always said, "it's all just a money making thing." I hate to agree with mom, but in my State it is a fact. What I have done is take every precaution I have ever seen on every website, and from every truck driver I have ever heard of, and cross my fingers. If I run into one of the "Peoples Party Commissars," on the road, I just Hang my head and wait for the inevitable fine.
   / Information Conflict from Tennessee #8
Simple fact is if it looks safe and you are not Commercial you will get a pass.
General rule of thumb around here is 10K and above chains on 4 corners. Under 10K straps are permitted. Each item on the deck needs secured. Straps are ok around these parts.
Heck, I saw a contractor yesterday with a BobCat and a ZTR on a trailer with not one single strap at the gas station. I asked if he strapped them down, he just grinned and said not if he was just going across town. Scary. No way I would ride with him. Quick stop and that BobCat would be heading toward the cab.
Chris
   / Information Conflict from Tennessee #9
In my experience, even if you are commercial they won't bother you if it looks 'right'. I've had more questions about my logbook (which was always right, by the way) than I have for the way my load was secured.
Landscapers and tow truck drivers scare me. I don't know if I've ever seen a ZTR mower secured in any way, just parked sideways on the trailer. Likewise, the rollback wrecker drivers that use the winch to pull everything tight. One weak spot in a hydraulic line, and you've got a big problem. Wouldn't take an extra minute or two to throw a chain and a binder on the front of the car, but I can't recall ever seeing it done.
   / Information Conflict from Tennessee #10
Chris
I saw an SUV on a multi-car haluer with absolutely nothing holding it down on the interstate the other day...I had to slow down to get a second look to see if it was for real...Unfortunately it was...It was the only vehicle on what looked like a GN 3 car ramp style trailer...I got away from him in a hurry.
2013 Cummins DSGAB 125kW Standby Diesel Generator (A56857)
2013 Cummins DSGAB...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A58214)
2012 JACK COUNTY...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2013 Peterbilt 365 Tri Axle Altec AC38-127S 38 Ton All Terrain Crane Truck (A55973)
2013 Peterbilt 365...
2017 Nissan Altima Sedan (A56859)
2017 Nissan Altima...
