Information Conflict from Tennessee
   / Information Conflict from Tennessee #11
I saw an SUV on a multi-car haluer with absolutely nothing holding it down on the interstate the other day...I had to slow down to get a second look to see if it was for real...Unfortunately it was...It was the only vehicle on what looked like a GN 3 car ramp style trailer...I got away from him in a hurry.
Whats the issue, he had it in Park and the brake set.:D
Chris
   / Information Conflict from Tennessee #13
Landscapers and tow truck drivers scare me. I don't know if I've ever seen a ZTR mower secured in any way, just parked sideways on the trailer.
I agree. I was working for a large (national) landscaping company and the folks there were annoyed that I insisted on straps to tie down the equipment. They said "but it is in an enclosed trailer, it isn't going anywhere". Eventually they bought straps and when I was with the crew, they were used.
Aaron Z
   / Information Conflict from Tennessee #14
More Scary: those who secure a skidsteer by throwing one strap over the cab.
   / Information Conflict from Tennessee #15
Well almost all of that contradicted what I thought was right so I called the Tennessee DOT and made the same statement: I'm looking at buying a tractor in Tennessee and wanted to find out the requirements for hauling a tractor on a flat bed trailer back to Alabama.
DOT reply: You're required to use a chain on each corner, that will be 4 per tractor. Any piece of equipment laying on the trailer, plows, etc will require two chains.
I asked: can I use the ratchet type web straps in place of chains?
DOT reply: No, only chains rated for the load are permitted. And each tie down point requires a separate chain. A long continuous chain tying down one side and extending across to the other side is not permitted.
I said: That's completely different than what the State Trooper office told me.
DOT reply: (Laughing) yeah, you're not the first one to tell me that.
I'm glad I called because I had intended to use my ratchet straps. I will now have to buy chains and binders / booms instead.
So much for the Tnn. DOT .
Now what about the Alabama DOT ,
FED Dot and any other state you pass through ??
You want the chains for sure. I have seen quick jerks snap decent size nylon straps.
1*The DOT told me, anything over 10,000lbs needs 1 chain at each corner (2 smalls not 1 long as you said) plus 1 chain per bucket. They didn't comment under 10,000lbs. I guess there is a wide variance from state to state.
1*Which Dot?
The best source of info is your state's DOT website. Not only will regs be clearly spelled out, but you can also print a page or two and take 'em with you. If there's a problem along the way, having a copy will go a long way towards showing the authorities you made an effort to be in compliance.
A couple of years ago, I watched in amazement as three or four other employees spent half a day talking to each other about, (and calling others to ask as well), what we needed to do to be in compliance because
2*we purchased another hydraulic tail equipment trailer that was located two states away.
2*So in this case which State has jurisdiction ?
   / Information Conflict from Tennessee #16
Heck, I saw a contractor yesterday with a BobCat and a ZTR on a trailer with not one single strap at the gas station. I asked if he strapped them down, he just grinned and said not if he was just going across town. Scary. No way I would ride with him. Quick stop and that BobCat would be heading toward the cab.
Chris
I've seen the local towing company hauling a small motorhome on a rollback UNSECURED, no tie downs at all. This is the same towing company that had a fire department aerial truck come loose and was totaled. :mad:
It was a year before they got a replacement ladder truck. In the meanwhile, they had to call for assistance from out of state whenever they had a major fire.
   / Information Conflict from Tennessee #17
Some TN Troopers are more relaxed about requirements than others, too. We got a new one recently -he's earned himself a reputation as a ticket writer.
I can't help with the details of what you're asking, but generally.... I'd trust chains and binders over nylon straps. It's your money (and your net worth if you get sued) riding on that trailer. Even if you're not at fault for starting an accident, you don't want to leave yourself open to someone saying you made it worse because whatever you were hauling flew off the trailer in an accident and landed on them.
Sounds like the state gave you the rules for equipment > 10,000 lbs.
I think you are right. I asked several guys in the local tractor club and they said the same thing. I found a Cub Farmall in White Bluff, TN and made it home without any problem. I secured the tractor on 4 corners with separate 3" ratchet straps and run a single strap through the two plows and another thru the cultivator. I counted 6 state troopers who passed me and several more local police / sheriff cars and none gave me more than a second glance.
And a side note:
Towing the trailer with the tractor and implements wrecked my gas mileage. I was pulling the load with my Toyota Tacoma with a towing package installed. I normally get 20 to 21 mpgs around home. This trip dropped me to just better than 12 mpg.
   / Information Conflict from Tennessee #19
Yes, that's what happens.
   / Information Conflict from Tennessee #20
Uncle Wayne, its not the regular troopers that will pull you over. It's those that drive the black Expeditions with the blue strobes built into the grill. But you are right, they normally don't bother with small trucks.
MAGNUM PRODUCTS LIGHT TOWER (A58214)
MAGNUM PRODUCTS...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
SNAPPER ZERO TURN LAWN MOWER (A52708)
SNAPPER ZERO TURN...
LOT: Cutters, Shears, Giant Chalk Line, 100' Tape Measure (A59076)
LOT: Cutters...
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
