John Deere Compact Pallet Forks ?????
   / John Deere Compact Pallet Forks ????? #2
Goochy I have the same thing, but of course they are SSQA the only difference is the attachment type, They are light but are strong, I picked up a huge rock with them 5 minutes after I took them off the truck to give them a work out.. they held up fine, they are easy to adjust and have worked out good so far.
James K0UA
   / John Deere Compact Pallet Forks ????? #3
Check out the Artillian units(advertised here). From what I've seen they are the best for your sub cuts.
Matt
Not going to use them much , so I am looking for best deal , to my door !
   / John Deere Compact Pallet Forks ????? #5
I've got the ones you have listed on my 4120 with 400x loader. They work great.
I've worked them over pretty hard moving a brush pile and a bunch of logs. If something was going to break easy a few of those logs should have done it and they didn't so I say mine have been good to go.
   / John Deere Compact Pallet Forks ????? #6
Thanks !
   / John Deere Compact Pallet Forks ????? #8
Trust me, Once you have them you will use them more that you can imagine.:thumbsup:
The Artillian forks are fixed at the top and do not slide on a bar-much better IMHO. The price is competitive also...and if you can weld you can buy the "kit" and save even more money.
Check them out at: Artillian Pallet Forks for John Deere Tractor Loaders
Chris-the owner and builder (It's a one man show) is a member here as well-username Ensoll.
   / John Deere Compact Pallet Forks ????? #10
I've got them and love them. Dont know why I waited...... I really like how they are designed; infinate lateral adjustment w/o notches.......I highly reccomend the CA Forks
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53472)
2000 Kenworth W900...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
