Use The Tractor, That's Why You Have It!!!
   / Use The Tractor, That's Why You Have It!!! #1
bp fick
Super Member
Beaver Creek, Northern Michigan
John Deere X390
Got this 5-600 lb bay window to remove. All by myself. Hmmmmm... get the tractor, that's why you have it, right? Done. :D:D
Told my wife she should have used the video setting.
   / Use The Tractor, That's Why You Have It!!! #2
Hook on and then....go ahead and back-up.:D
   / Use The Tractor, That's Why You Have It!!! #3
Wow, Kubota power ,,,I guess you are not going to put it back...Remodeling, a permaent occupation at home.
   / Use The Tractor, That's Why You Have It!!! #4
With my luck, the whole front wall of the house would come down with the window still attached. :(
   / Use The Tractor, That's Why You Have It!!! #5
Ditto that. BP, you're a braver man than me! Actually, I've got a bay window replacement in my future as well, and I guess you've given me another technique I hadn't thought of. Don't know if my better half would stay calm as I chained the tractor to the kitchen window. Stay tuned...
Come on, guys. You gotta know what's attached and what's structural. You've pushed out an old window or door before, right? Same thing.
I had prepped that bay, It was just setting in there, but tight as can be. But how is one guy gonna push a 9' bay window frame out? That sucker was heavy. You don't just jerk it all at once. You pull, very, very gently on this spot and that spot, watching to see how it moves.
Ah, an HST on the tractor is highly recommended!!
I've installed bay windows before, (along with 5 other guys helping hoist) but this was my first demo. It went very, very well.
It's really no different than pushing out a little 3x4 double hung, only on a much larger scale.
   / Use The Tractor, That's Why You Have It!!! #7
I just put this up a few days ago. Its about 700 lbs of mostly cast iron. Not the modern versions in aluminum. It takes a tractor loader with a pretty strong boom pole on the bucket to set this baby up on its feet (14' high).
‪July 21, 2011‬‏ - YouTube
Way too cool!!!!!
   / Use The Tractor, That's Why You Have It!!! #9
EXACTLY! And enhance it if you can.
   / Use The Tractor, That's Why You Have It!!! #10
I see your place is on the main line ... nice!
Is your tractor steam or diesel-electric?
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2014 Ford F-150...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
