3-Point Hitch New Holland 1715 lower lift arm question
   / New Holland 1715 lower lift arm question #1
bucknbass
New Holland 1715
I've got a model 1715. There's nothing that I can see to keep the lower lift arms fixed and straight behind the tractor when pulling my finishing mower. As a result the mower slides side to side in a turn and the bolts on the arms and the arms themselves hit the rear tires.
Am I missing an adjustment somewhere to kep the arms straight when hooked to an implement? I see the turnbuckles on each side but it seems like they would adjust the arms out, not in.
   / New Holland 1715 lower lift arm question #2
There is a "turn buckel" on each side, 1 for each lift arm. They are adjustable to shorten or lengthen using the turn buckle. They have 1 lock nut that has to be loosened before they will turn. Attach your brush hog and lift it slightly off the ground and thghten (shorten) both turnbuckles to remove the side by side sway. Re tighten the lock nut and it will not move while mowing. You might have to loosen them to get the mower unhoked when changing implements. Turn buckels adjust both ways (in aand out) (longer or shorter) Shorten them to remove sway.
   / New Holland 1715 lower lift arm question #3
Those turnbuckles work the opposite of how you would first think they work. When you tighten the one on the right it keeps the implement (or lift arm) from swinging too far to the left. That keeps the lift arm from hitting the left tire. When you tighten the one on the left it keeps the limplement or lift arm from swinging too far to the right hitting the tire on the right. Tighten both to the to the same length to center the mower. I hope that is clearer than my above post.:)
Perfectly clear! Thanks very much for the information. It will save my tires!
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
