Is it necessary to bleed the hydraulics?
   / Is it necessary to bleed the hydraulics? #1
jtheise4
SE Michigan
Massey Ferguson 1643 & Allis-Chalmers D14
I recently changed the hydraulic fluid on my Massey Ferguson 1643. I have a DL120 loader on it and its a hydrostatic transmission. I've been using the tractor for the past 3 or so hours and every thing seems to be working just fine. I was glancing through the owners manual last night and noticed that several pages after the section on changing the hydraulic fluid, there is a section of the manual that recommends bleeding the hydraulic pump after changing the hydraulic fluid. I always thought tractor hydraulic systems were 'self bleeding'. Am I wrong? Is it really necessary to bleed the system? Thanks.
   / Is it necessary to bleed the hydraulics? #2
Depending on the system style they may require bleeding.
1) If this was a closed center pressure comp pump it may not prime properly since it is being "dead headed" at start-up. This can be over come by looping the work ports on direction valve and then holding the valve so flow can pass through it at start-up.
2) Problem with hydrostatic is they are a closed loop system so if they are truely drained they require a start-up sequence that bleeds the air out under very low load conditions. Since you did not drain the HST you should be good to go.
Roy
Roy
Actually, I did drain the HST. On my tractor, there is only one hydraulic reservior for the HST, power steering and hyrdraulic remotes.
   / Is it necessary to bleed the hydraulics? #4
Yes you drained the reservoir for it but you did not open up any lines between the HST pump and motor. It is when you open these lines that air gets into the closed loop portion of the HST and can cause problems. Yes you can potentially get some air in the HST from the charge loop if it drains out but this is usually bled out when the charge goes over it's relief valve.
Sorry for the confusion or any concern this may have caused.
Roy
Roy
Got it! Thanks for explaining.
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
2000 Sterling L9513 Winch Truck (A53472)
2000 Sterling...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
Unused Delta Crash...
