Lubricating questions on TC 30 New Holland
   / Lubricating questions on TC 30 New Holland #1
diamond dave
new holland
I am helping a woman who owns a NH TC 30 to maintain her tractor.
How many quarts of oil does a TC 30 require with an oil change and filter? Also where is the oil filter located?:)
Diamond Dave
   / Lubricating questions on TC 30 New Holland #2
This TC-Series link should get you started. It does not give fluid capacities but my 33D needs 1gl for an oil change.
Larry Thanks for the info.
DD
   / Lubricating questions on TC 30 New Holland #4
You might want to check my following advice but I did read this somewhere on TBN. When adding oil to a TC series tractor, add the oil slowly. Why? If the oil puddles on top of the cylinder head it will run down the positive crankcase ventilation (PCV) hose into the intake manifold. When the tractor is cranked, the oil will be pulled into the cylinder thus causing a hydraulic lock resulting in a bent piston connecting rod.
Two years ago a person asked me why his engine was knocking after changing the oil. He also said it was like the battery was dead but did finally start and began knocking and misfiring on one cylinder. At that time I did not know the answer.
   / Lubricating questions on TC 30 New Holland #5
I also recall that sad tale. I expect adding a quart then waiting 10 seconds or so and adding the next if fine, I don't know for sure. Also, I think this is only true on some models, but I don't know which ones.
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2000 HEIL 41FT TRL PNEUMATIC TRAILER (A53426)
2000 HEIL 41FT TRL...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51692)
Heil V-1722 28Yd...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2017 Can-Am Side by Side (A51694)
2017 Can-Am Side...
