Troy-Bilt pressure washer - cost of new pump?
   / Troy-Bilt pressure washer - cost of new pump? #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
I was using my 4-5 yr old Troy-Bilt 2300psi pressure washer with 6.75hp B&S motor the other day and I looked back and all of a sudden there was oil pouring out from underneath the pump. I ran back to it and looked to see where it was coming and it was coming from the water pump. I haven't looked at it close enough to tell where the leak was at, and I didn't hear any metal crunching noise, but I can probably assume there may be some damage to the insides of it.
Anybody have any idea about how much a new pump will cost? Is the pump on these just more chinese junk? I'm going to make a guess that for the cost of a brand new pump, I can probably add a few more bucks and get a whole brand new pressure washer? If true, that would be a shame cause this one really doesn't have very much use on it, and the motor runs just fine.
Any thoughts/comments/suggestions???
   / Troy-Bilt pressure washer - cost of new pump? #2
I recently just found myself with the same problem. I had a 3000 psi 3 gallon a minute Honda north star pressure washer. It was a good machine I had it for about 8 years. Then a couple of weeks ago the pump would not build pressure. I looked into replacement pumps but the ones that were compatible were around $500. So I ended up going to my JD dealer and got a new JD PR-3000GH. It has a Honda motor and Is 3000psi and 2.4 gallon a minute. All said and done I got a little bit knocked off and got out of there for a little under $700. I know it is not exactly the same but it still works great. The PR line is JD middle line. You also can save about $50 if you go with a Subaru engine. Hope this helps.
   / Troy-Bilt pressure washer - cost of new pump? #3
Yes they are Chi-com junk but they are serviceable. Carefully crank it over with the plug removed and see where the oil is coming from. Chances are it is just a gasket and you can fix it with high temp permatex and a quart of new pump oil.
   / Troy-Bilt pressure washer - cost of new pump? #4
Kind of doubt it's a gasket, could be, but not likely. Probably leaking between the ceramic plungers & oil sump.
   / Troy-Bilt pressure washer - cost of new pump? #5
'Chi-com" Haven't heard that term for about 40 years.
   / Troy-Bilt pressure washer - cost of new pump? #6
Don't know if you still have the unit, but mine stopped building pressure as well and when i took it to the repair shop they said the pump was shot and it would cost approx 200 to fix. I left not wanting to pay that much to fix it, so i tore the pump apart and found dirt in the pressure relief valve on the side of the pump. I put it back together and it still didn't work so i loosened the pressure relief port adjustment screw and backed off all of the pressure and the pump started working. After it had some time to flush the system i tightened the screw back up and the pump built pressure and works fine. When i called the service center to explain what i found, the guy told me that because the pumps are so expensive to repair they just tell people to replace them.
To make a long story short, if you still have your old unit you may be able to clean the pressure valve and have a backup unit.
   / Troy-Bilt pressure washer - cost of new pump? #7
I have a Troy Bilt 3000 psi unit. I got less than a year out of it. Took it to a local repair shop. Spent $200 and got another hours use out of it. They are not able to obtain a replacement pump from their suppliers. I have found out that units in the $400 +/- range are designed to last about 50 hrs. In order to get a unit that will last longer you have to spend $1100 + or there abouts. You have a choice you can spend the $'s and get some life out of it, or you can buy probably 3 of the low end junk and throw them out when they quit, which will be soon! I did find a replacement pump on line fro about $260 which I might do - something inside me makes me cringe at the thought of throwing out a perfectly good motor, frame, detergent tanks, wand, etc.
   / Troy-Bilt pressure washer - cost of new pump? #8
I had the same dilema and finally bought a new pump from We offer the choice of parts breakdowns, Pumps, Repair Parts and accessories as well as new pressure washers. the pump was on sale for $150 and comes with a warranty. The pump looks better built than what came with the original system and bolted right up. I have used it several times and everything works fine.
   / Troy-Bilt pressure washer - cost of new pump? #9
From what I unerstand the pumps made of brass are better than the ones made of aluminun.I've been thinking of buying one but haven't done enough research yet as to brand...russ
PALLET OF JACKS AND STANDS (A53843)
PALLET OF JACKS...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
DESK (A53843)
DESK (A53843)
