Which tractor do I need?
   / Which tractor do I need? #1
Khiggins
None
I have about 30 acres with the strong possibility of getting another 50 or so in the next few years. The land consists of about 12 acres rolling fields, a creek, and the remainder in woods with some hills. I like the 5055e 4wd, I have never owned a tractor and don't know what to buy? I will be bush hogging, digging, clearing paths, clearing a place for a house, grading, gardening, and moving debris around. My father in law, who has used a ford 2600 for everything his whole life to do everything under the sun, went to the jd dealer and said I should get the 4005? I want a fel, grader box and a 6 or 7 ft bush hog, and a set of pallet forks.
   / Which tractor do I need? #2
Welcome to TBN, Khiggins. So, you've got around 12 acres that you'll be actively working each year and some added chores in the woods as time permits... 'bout right?
And maybe another 50 acres on the far horizon?
Don't mess around and spend nearly $30K for the 4005 with attachments!! :thumbdown: You'll end up selling it and taking a big hit when you move up to the 5000 series tractor!
The 5045e thru 5075e are the same tractor - identical - except for the turbocharger and injector pump/injectors. And they're not a whole lot more $$ than what you'll have invested in the 4005!
Have you or your FIL done a "side by side" sit in the seat and run the machine comparison of the 4005 or the 5000e's?
When I was looking at upgrading to either a 4000 series or a 5000 series machine... my wife says at the dealership one day -- heck, they're almost the same size!?!
(Why would I argue...?)
AKfish
I thought the 5000 series was a better fit for what I need but am being told it's too big, I have only looked at the 5055e and the 5075e as my local dealer has a 5075e on the lot. I have not even seen the 4005 in person. What are the downsides of the 5055e over the 4005 and what would a 4005 be able to do vs the 5075? Is the 5055e not as safe because it is heavier and taller? Thanks for the info! I only want to buy once!
   / Which tractor do I need? #5
I'm in the same boat as you and I've considered both machines too. The 5000e is a lot more machine with a better tranny and really the only drawback I can see is it is a little taller for getting under limbs, and a little larger turning radius. But you can get the exhaust mounted horizontally and fold down the ROP so it may have an advantage there too. Im still undecided on how much HP I need and how much more fuel each model uses but I've narrowed my choices down to one of the 5000e or a similar model from another manufacturer. I really think I like that green paint better though!:D Let us know what you decide!
   / Which tractor do I need? #6
My 5055E was dropped off Saturday morning and I can not be more pleased with my decision. Not a lot of bells and whistles, just a solid running machine. :thumbsup:
   / Which tractor do I need? #7
the 5055e is cat2, and the 4005 is cat1 if that makes any difference to you. cat2 equipment is usually stronger and bigger, but also more expensive. ask yourself how long you want be mowing, then figure out what size mower will get the job done in that amount of time. that will give you an idea of what size tractor to buy.
   / Which tractor do I need? #8
i paid $21470 for a 4005 with loader, two rear remotes, canopy, wheel spacers, and loaded rear tires. the 5055e list for over $24000 without the loader.
   / Which tractor do I need? #9
If I only could have 1 tractor, I would go with the bigger 5055e and a 6 foot cutter. The bigger wheels ride better in bumpy conditions and give you a much better chance of getting unstuck when you slip it into 4WD(after getting stuck in 2WD).
The fact you mentioned pallet forks tells me you want to lift stuff and you'll get a lot more lifting capacity with the bigger machine.
The main things you'll give up is maneuverability in tight spaces and a bit less fuel while piddling around. Once you hook up a mower and get into the deep grass the fuel usage difference will be minimal. Are you going to be cleaning out stalls?
Is there anything a 4005 can do that the other won't, besides turning tighter and possibly going under some tree limbs? Are the large front tires an advantage or disadvantage? I sure like the way they look but what about performance?
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2016 Toro Workman HD-X 4WD Diesel Utility Cart (A59228)
2016 Toro Workman...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2011 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2011 VOLVO A40F...
