chopped
I cut tires all the time with a sawzall.Use bolt cutter to cut metal bead.Bot sure how many metal strands ya would find ...
Hmmm.. JD, I figured the closer the rubber resembled the steel blade - the higher likelihood I would get similar results. I can see some appeal to leaving one inner ridge to act like a bottom ledge/scoop .. but does not leaving the top inside edge start a premature roll of the snow .. or is it not enough to effect it?
Needless to say, you cannot see exactly what is going on upon contact, but do you have a general idea of how much distortion you get with the rubber edge.
I was also looking at this 1" plastic edge .. seems a pretty good deal for those without trucker throwing rubber gifts:
IPX 2000 UHMW SHEET - Plastic Rods
You guys - would a hole saw work better than a twist bit?
I am not looking forward to drilling all those steel holes either! Thanks.
Jim
