Kubota hose diameter question, ready to order.
   / Kubota hose diameter question, ready to order. #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
I am trying to install a 4 spool valve on my kubota L4610. I measured out the hose lengths and want to order them on discount hydraulic hose.com. The only problem is, I forgot to check what SIZE hose I need! I won't be around the tractor for the next 2 weeks and will wait to order if I have to, but if someone could tell me what size hose I need, that would be awesome :thumbsup:
If it helps, the ports for the valve are all SAE #8 except the PB port which is SAE#10.
I assume it's the same size hose as other similar sized L series Kubotas. (40-46hp)
The only hose diameter I snapped a picture of, was my WR Long 3rd function solenoid valve hose, which is 3/8" but that seems small for the rest of them?
   / Kubota hose diameter question, ready to order. #2
Check you data, here is the specs. All ports are 8 except the OUT port, and it is a 10.
Do you realize the factory relief on your new valve is set at 2000. Install a gage and reset it to equal the FEL PRV.
Specifications for Y valves
Flow 12 GPM (nominal) to 16 GPM maximum
Pressure 3000 PSI maximum
Adjustable relief 1500-3000, factory set at 2000
Open Center with Power Beyond
Inlet and Power Beyond Ports SAE 8
Outlet Port SAE 10
Work Ports SAE 8
I've looked at the specs but get confused. My question is what size hose do I need?
:thumbsup:
   / Kubota hose diameter question, ready to order. #4
1/2 in hose
The OUT hose will have a SAE10 fitting on a 1/2 in hose, and what are you going to do with the end of the OUT hose, couple it to another return hose.
1/2 in hose
Thank you :thumbsup::thumbsup::thumbsup:
That's exactly what I was looking for. :D
I will tee the OUT hose into another return hose, I just don't know which one, or where, or how to do that yet?
CASE INTERNATIONAL 183 4R DANISH TINE CULTIVATOR (A52708)
CASE INTERNATIONAL...
PALLET OF DISHES (A58374)
PALLET OF DISHES...
2018 Ram 5500 4x4 Crew Cab Flatbed Utility Truck (A55973)
2018 Ram 5500 4x4...
20357 (A55758)
20357 (A55758)
HOOPER 10 TON GOOSENECK TRAILER (A52708)
HOOPER 10 TON...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
