Prefill Hydraulic filter, yay or nay??
   / Prefill Hydraulic filter, yay or nay?? #1
sweep
Gold Member
Ohio hill country
2006 TC45A
Just changed my hydraulic oil and filter. Do I prefill the new filter?? if so 1/2 full or 3/4???
I thought I heard at one time prefilling them full can cause them to burst???
Thanks
   / Prefill Hydraulic filter, yay or nay?? #2
Thanks
Sweep,
I never heard that. I never have pre filled hyd. filters.
Only filter I prefill is the fuel filter on my Cummins and that is just sinking the filter into the fuel in the canister without spilling any.
hugs, Brandi
   / Prefill Hydraulic filter, yay or nay?? #3
i usually prefill any filter that is vertical, and mounts with open face up. if vertical, and open face down.. nothing.
if horizontal, then i add 1/4 full.
oil pressure is max at cold start and running and primed. how would a filter burst from prefilling? it's made to take that max pressure an more. nothing magic happens to increase the pressure in a pre filled filter. any air in there is going to compress anyway, and any air int he system will be expelled and purged thru oil ports and clearances..
soundguy
   / Prefill Hydraulic filter, yay or nay?? #4
If it's a return filter I can't see the sense in it, the oil is going thru the system and then thru the filter before it goes to the tank.....Mike
   / Prefill Hydraulic filter, yay or nay?? #5
Thanks
depends on the location and purpose for the filter. If it is being used to filter oil to the turbo charger then I would definitely prefill it.(Had one tractor this way) Problem is that a lot of the oil coming out of the container is dirtier than what has gone through the filter.
If like Mike says it is in a return line why bother.
Like soundguy said. What is going to cause it to burst?
   / Prefill Hydraulic filter, yay or nay?? #6
I will prefill any filter that can be prefilled. It will get oil pressure to the working parts sooner.
   / Prefill Hydraulic filter, yay or nay?? #7
I change a fair amount of these things and always at least get the filter media completely soaked in fluid and then partially drain them if necessary, it is the way I was taught and has become habit over the years.
   / Prefill Hydraulic filter, yay or nay?? #8
If you fill from the outside holes and not the centrer the oil to the eng, hyd or whatever system its for will be filtered.
   / Prefill Hydraulic filter, yay or nay?? #9
I believe prefilling filters is bad practice and do not do it unless specifically advised to do so by a machine's operator's manual. Such recommendations are few and far between.
   / Prefill Hydraulic filter, yay or nay?? #10
Can you please explain why pre-filling a filter is a bad practice?
378811 (A51573)
378811 (A51573)
2007 International 4300 Dump Truck (A51692)
2007 International...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2018 FORD F150 XL TRUCK (A51406)
2018 FORD F150 XL...
2005 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A54313)
2005 FREIGHTLINER...
