Mini log skidding BX style
   / Mini log skidding BX style #1
HarleyScooter
Gold Member
Canton, Ohio
Kubota/ BX2230
I built a small attachment that was added to the three point hitch, to lift and pull small logs. It worked good but you had to back up over the end of the log. With the low ground clearance of the BX I thought it would be better to add the winch I made for the three point hitch so I could pull the logs to a open spot where the tractor was safe. Here is some pictures before the winch.
Here are the pictures of the winch added to the system.
   / Mini log skidding BX style #4
very cool. I like it! That is going on my wish list to do.! :thumbsup:
   / Mini log skidding BX style #5
I like your thought process of improvement after initial build. Very innovative design. :thumbsup: Seems you could use the back plate as a dozer blade as well? Are you able to skid more than one log at a time?
magicheater, I have not skidded more than one log at a time, I did make slots in the top of the plate to hold chains, so I could chain more than one log at a time. I guess it would depend on what size logs the BX would pull.
   / Mini log skidding BX style #7
Very nice job :thumbsup::thumbsup:
What are you using for a winch ?
The winch is a Warn 2500 lb, I had it on the ATV and never used it. I thought I would use it more on the tractor?
   / Mini log skidding BX style #10
Nice setup Harley, for some reason it reminds me of hauling pulpwood when I was a kid.
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2014 FREIGHTLINER...
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
40ft 6-Door Shipping Container (A52377)
40ft 6-Door...
UNUSED LANDHONOR BH-12-72D BACKHOE DIGGER ARM (A54757)
UNUSED LANDHONOR...
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
