Wind Rows!!!!
   / Wind Rows!!!! #11
Thanks to all who have offered suggestions. I have decided to try watering for 45 minutes per zone on Tuesday, Thursday and Saturday nights. I cut the fields on Tuesday afternoon and Friday afternoon. I am also going to raise the rear 1/4 to 1/2 inch compared to the front adjustment and see if I get as smooth a cut....but with less wind rowing. The grass is really thick and beautiful. I have used 200 pounds per acre of 28-0-5 slow release turf fertilizer and applied in mid May and again about 2 weeks ago. I sprayed with roundup in January and February to kill the clover and winter weeds while the bermuda was dormant and then sprayed with Stonewall as a pre-emergent in mid March. This was to control the crabgrass which is endemic here in Alabama. I found out 2 years ago how bad the crabgrass can be!! Last year I used Pendulum pre=emergent but it only lasted 10 to 12 weeks. I then had to spray with MSMA which really yellowed the bermuda for 2 or 3 weeks, but it did recover. I now have a couple of areas that some slightly thicker bladed grass is breaking through, but it is not a running grass like the crabgrass. It is not a large amount and I am afraid to spray it with anything and it doesn't look too bad. Probably no one but me will even notice itsinc it is growing right in the middle of good bermuda. The main thing is no clover, johnson grass, or grass that runs and spreads!! Thanks again to all you gurus. By the way, Talstar P has been absolutely fantastic in controlling the ants, fleas and other critters. Amdro and other powders really didn't cut the mustard on the ants.
If you are going to cut on Tuesday and Friday afternoons...
Why don't you water on Tuesday, Friday, and Sunday nights instead so that there is plenty of time for drying... And the grass will be watered after it is cut.
Also, make sure that the sprinkler isn't watering if there has been adequate rain in the prior 24 hours.
   / Wind Rows!!!!
I do this as a volunteer at my church. It is a "Upward Soccer" league that plays in spring and fall. It is somewhat expensive, but it is really worth it when you see a couple of hundred kids and all their parents and grandparents having some good clean fun! One of the local schools gave us 8 sets of their bleachers they were replacing and with just a minimum of work, we reworked them and they serve us well.
   / Wind Rows!!!! #13
Great work! Good for you!!
The country would be a better place if more of this kind of stuff was going on. Thank you for your contributions.
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
Test Button (A47477)
2018 Ford Explorer AWD SUV (A55758)
2018 Ford Explorer...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A55788)
2014 Ford F-550...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
