Larry Caldwell
Elite Member
1) Where can I find 55 gal barrels without a top so I can use them for a burn barrel?
Try an ice cream company. They get syrups, chocolate, etc. in teflon lined 55 gallon drums, and the tops come off so they can get all the goo out. Sometimes you can get a couple pounds of chocolate left in the bottom of a barrel. :licking:
I have one that started life as a shooting target. It has several hundred holes in it, from .22 caliber up to shotgun slug size. Burn barrels take a lot of ventilation.
2) The prior owner had a burn pit that is full of stuff you should NEVER burn due to either it is inflammable, toxic, or other. Glass, fiberglass, plastic, car seats hot tub covers, etc. It is a MESS, some is burned, some is not. It is very close to one of my ponds, I dont want to poison the water (it is spring fed). Do I get a dumpster and dig it all out? What is the best way to handle this?
Yeah, the best thing to do is dig it out and haul it to a landfill. I bet you have other artifacts that need to be disposed of. When I bought my place, I hauled 28,000 lbs of scrap metal to a dealer, and filled six large dumpsters with the contents of the barn. You really don't want to burn anything plastic. It generates toxins that settle out and persist around the burn pile for years.
3) I have found a couple 55 gal drums with I think diesel in them scattered around the property. I also have a totally rust covered old style propane tank that is (of course) FULL! Can I siphon the diesel and use it? do I burn it? what can you do with a FULL but useless propane can? See question 1, can I empty the diesel (and water in some cases) and cut the lid off to make a burn barrel?
Some states have programs for decommissioning buried fuel tanks that will pump out and recycle old fuel oil, which is the same stuff as #2 diesel. They donate the proceeds to winter heat support for poor people, and the process doesn't cost you a dime. If it's fuel oil or diesel, the stuff in those barrels is worth about $2 a gallon even if it needs a lot of rehabilitation, so don't let anyone charge you for taking it.
Keep at least one barrel around if you plan to get a tractor. Rinse it out, give it a coat of paint and get a barrel pump and it will save you hauling tractor fuel in 5 gallon cans. Stabilize diesel that will be stored over a year, add a filter to the barrel pump just in case, and keep it someplace dry.
Use the propane tank to run the propane weed burner. You really want a propane wand. It's great for getting brush piles started, burning weeds out of gravel, heating castings before you weld them so thermal stress doesn't crack the weld, etc. etc.
4) One of my daughters is terrified of snakes. I've seen a 6-7" black rat snake and several smaller snakes on the property (none lately) but no copper heads yet. Is there a simple and easy way to keep snakes out of the "Yard" area?
Teach her to love king snakes, which are easily recognizable and eat rattlesnakes.
Those little windmill thumpers that are supposed to run off gophers work pretty well on snakes. Snakes hate vibrations in the ground. They are afraid of being stepped on, and will leave an area where the ground vibrates.
5) My other daughter is terrified of ticks. I got guinea fowl patrolling the yard and I hope that works. Is there anything else I can do non-chemical (my wife is VERY pro-organic type).
Your daughters will adapt to country life. So will your wife. Give them time, and buy them boots. Teach them to keep their pants tucked into their boots while walking. Insect repellent also works on ticks, but gee, that's a chemical.
6) Grass in the gravel drive. The 1 year total kill (I only use it on the gravel) only lasted 3 months max. How the heck do I keep the gravel clear of grass/weeds?
Get a 3 point blade with your tractor. You will need it to maintain the drive. Blade the drive smooth before adding gravel. Blade the gravel thrown to the sides by tire action back onto the drive. Your "total kill" sounds like glyphosate, and 3 months is about how long it takes new seeds to get established. You can either use glyphosate in between tractor blade jobs, or there are more effective soil sterilants on the market.
7) Related to gravel drive. when to buy more gravel? I know that the immediate "driveway" and the "y" in front of the house NEED more gravel, as does the main hill portion. What season is best to add gravel, and must all the weeds be dead first, etc. The driveway is how I get to work, which pays for all my tractor parts and tractor payments...
You need to crown the driveway so you don't get puddles. Drive through a puddle and the splash throws gravel out of the puddle, which just gets deeper and deeper until you have lakes in the drive. Water running down the hill will carry gravel along with it, and turn your driveway into the Grand Canyon. You have to get the water off the road. Ditches and water bars are called for if you can't crown the driveway to keep it dry.
The best time to blade a drive is when the soil is moist but not wet. It takes moisture to compact fill. If you really want to do a job that will last, blade the drive, top dress with gravel with plenty of fines, then compact the gravel with a vibrating roller. You might want to add a couple speed bumps, because a compacted drive is almost as smooth as asphalt. If your hill is steep you might want to post a sign limiting traffic to 4wd vehicles. Tires spinning out cause washboarding. If 2wd is all you have, post a sign telling people to stay off the gas. Lead footing causes washboarding.
