Anyone using a Howse Subsoiler?
/ Anyone using a Howse Subsoiler? #1
dlmpsy
I'm thinking about buying a three in one Howse subsoiler. It is a combination subsoiler, middlebuster and can be used as a hitch for a trailer. Apparently these different parts are a matter of removing and bolting-on the different attachments. I was wondering if anyone has used this implement, and has any comments regarding the units quality. This picture shows a little about appearance of the implement.
/ Anyone using a Howse Subsoiler? #2
I have one and it bends easily being made of only the finest Chinese steel. My mighty 29 hp Kubota is just too much for it. So enjoy.
/ Anyone using a Howse Subsoiler? #3
I bent the foot on mine while ripping some old cedar roots. I got the root out but it was so big that it got stuck under my Branson. That 3pt hitch has some power. :thumbsup:
If I'm not mistaken, their subsoiler is made in USA. That's what Howse said when I called them.
So, it sounds like you're satisfied with the subsoiler?
/ Anyone using a Howse Subsoiler? #6
Actually there were two different attachments when I bought mine. I bought what was the Middle Buster, removed the sweep and bolted on a pointed chisel. The "Subsoiler" had a flatter foot angle than the middle buster and might be stronger "or not". Otherwise the two are identical. The forged chisel I put on might be a little longer and therefore more leverage on the foot. Understand, I not only bent the foot but also the 2 5/8" bolts holding it on. Hey, I got the stump out.
Using the subsoiler to cut roots is one reason I need one. At some point something has to give, better the tool than the 3 pt. I guess.
/ Anyone using a Howse Subsoiler? #8
This culprit here was an old cut cedar, about a 15" tree. You never know if a cedar has rotted or not. Either way they last a long time in the ground. I hooked the chisel under the stump and then raised the 3pt to pull upward. I did this several times, finally tearing it loose. I'm 6'1" and 220lbs and it took all I had to roll the stump into the bucket.
No, I wasn't surprised that I bent the subsoiler, nor was I upset. The labor it would have taken to dig out that stump would far outweigh the repair on the subsoiler.
I have some old locust stumps in a field I am reclaiming, sizes are generally around 8". I'm tired of hitting them with the bush hog, and dealing with the sprouts that are always popping-up, so they 'gotta go. I used my boxblade to get some out...and it actually worked pretty good, but I figure there is a better tool and I've read on this forum that many seem to like a subsoiler for this job. I figure that I'll cut the roots, and if the stumps are smaller in size maybe just pull them out with the subsoiler, if they are bigger, I'll use a chain after cutting the roots. That's my theory anyway.
/ Anyone using a Howse Subsoiler? #10
Chinese bolts no doubt. Howse is located in Laurel, MS about 80 miles from me. When I discovered an almost local manufacturer I was delighted. I bought a dirt scoop from them and it lasted one weekend with my mighty 29 HP Kubota. The dealer took it back and said he had never seen a scoop bend like that. I got a King Kutter and have been happy ever since. I had also bought a Howse multi purpose, sub soiler and middle buster. The large horizontal angle iron holding it together is what bent on mine. Plus the furrow broke in two. When I called Howse to complain the company itself said the steel was fine Chinese steel, so I did not make that up. Since then I have been a no House zone and very happy.
2015 Chevrolet Silverado 3500 Pickup Truck, VIN # 1GB4KZC88FF627993 (A65563)
2015 Chevrolet...
Skid Steer Power Broom (A65640)
Skid Steer Power...
Ford 3430 Tractor (A65579)
Ford 3430 Tractor...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
John Deere 2032R Tractor and Loader (A66285)
John Deere 2032R...
