L3400 front tire problems
   / L3400 front tire problems #1
Chilly807
Elite Member
Nova Scotia
Kubota L3400DT
My '09 L3400 has R1 (AG) tires all around, the rears are made by Firestone, the fronts by Carlisle. I think they're called Farm Specialist, or something like that.
I noticed today that both fronts have developed bulges in the outer sidewalls at the end of the tread bars. It's pretty obvious that air pressure from the tire is directly under the bulges, since they are soft enough you can press them in with a fingertip.
For air pressure to be there, it tells me the sidewalls are coming apart internally, there should be at least a couple of layers between the inner part of the tire and the outside of the sidewall.
They've been aired up to normal as the manual specifies as long as I've owned the tractor (since new), and I've never been overly impressed with their load-carrying ability. With a full bucket of earth, they're almost flat from the operators view.
The sidewall specs say their max load capacity is 1100 lbs. To me, that's a joke for any front tire on a tractor with a loader. R4's aren't an option for my use, so something different is going to have to go on.
Has anyone else had this problem with R1 tires on their L series tractors?
Sean
   / L3400 front tire problems #2
I would say that would be a tire defect. Call Firestone and tell them about this issue. They should replace them without question and without charging you.
   / L3400 front tire problems #3
Opps.. My bad!! Call Carlisle and tell them about the issue.
   / L3400 front tire problems #4
Those tires are junk.. if used as tubeless. But if you put a tube in them they will work.
You 'almost' got the tire size into the picture...
KennyV
KennyV
They're 7-16...
So, you're saying that if I tube the existing tires they should be ok to use? I hadn't considered that..but I think you may be right. If it goes that route I'll take a look at the inside first and see how much damage there is, if any is visible at all. I'm going to approach Kubota and Carlisle first and see what they have to say.
Sean
   / L3400 front tire problems #6
You would want to check the inside of the casings before installing tubes to be sure the cords are still intack so they won't puncture the tubes.
I would contact the manufacturer as to a potential adjustment towards a new set.
   / L3400 front tire problems #7
Firestone would replace them but I have no experience with Carlisle. They should replace them also.:thumbsup:
   / L3400 front tire problems #8
I wouldn't use the tires even if you use a tube. The damage has been done and the tire will not be able to handle pressure with heavy loader use. It looks like you have a lot of meat on those tires so they shouldn't use excessive tire use as a reason not to replace them.
   / L3400 front tire problems #9
No kiddin kuboman... For the problems they had in the past with tires on SUV's, Without a doubt!!! HAHAHAHA!!!!
That's the course of action I'm probably going to take. It's possible that they are defective, but after re-reading my owner's manual it seems Kubota recommends a higher tire pressure if using a loader. It would have been nice if I'd known that two years ago when I bought it, but that's just the way it is.
As it is Kubota doesn't warranty tires, at all. Carlisle might, I'll give them a try on Monday.
These have nylon plies, so I'm not concerned about steel wire in this case.
Sean
71061 (A49346)
71061 (A49346)
Ford 641 Workmaster (A50514)
Ford 641...
CATERPILLAR D6R XL CRAWLER DOZER (A51242)
CATERPILLAR D6R XL...
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
