I agree with bigfoot.
Could be worn rings but if it was sudden then i dont think that is the case. It will always have something most likely but increase is prolly just moisture from rain or condensation from high humidity maybe. Check that coolant level and for bubble in the radiator to confirm no blown head.
Edit:
Meant to also say that id make note of it, change the oil, check it again after an hour of running it. Then keep a check on the coolant to make sure your not loosing any into the oil. But if those things check out ok and you have good power, just run it and dont worry about it as long as you have adequate power.
i have seen a vid on youtube of blowby that looked like a little exhaust pipe there was so much! Mine has as few drips as i bushhog of oil that is slung up there i guess or condenses maybe, not constant but just a bit after running, not sure i have even seen a spot on the concrete the few times i have parked on it. And after a hard run i see if i look hard very faint smoke or condenstion burn off? But i have to look and concentrate to see it!
