How to remove bamboo
   / How to remove bamboo #1
deepNdirt
Nth East Ga, USA
yanmar YM-1700
What would I use to cut bamboo?, 1/4 acre of it to be exact, I never had any dealing with brush cutting this stuff so I'm not sure this is even an option...
I've not seen the patch of bamboo yet, but what I have seen in the past is that this stuff grows in thick tall stalks, I'm not sure of what to use to cut it, I have used a machete to cut a couple of stalk down to use as cane poles, although I certainly wouldn't hand cut 1/4 acre of this stuff like that, what would you use?
Thanks
   / How to remove bamboo #3
...do you want to get rid of it?
Good luck with that :D a Friend would like to get rid of some... mowing it just made the bamboo get mad and sprout even more...
I'm really not sure how he wants it removed, I am supposed to meet with the man tomorrow and go over what he wants, if I'm thinking correctly doesn't most of this stuff grow in marshy area's? if this is the case My 2 wd tractor is not the tool, and he might have plans for me trying to push it up by the roots, But just in case he wanted it cut I is reason I brought the question to you folks.... what method to use to cut it? would a sickle cutting blade be be the tool? or would it be large enough to cut through the stalks?
   / How to remove bamboo #6
Ah, you are cutting it for someone else... Find out what his plans are. Chemicals are going to be one of the better ways to get rid of it. It will also take a couple of years...
Bamboo can be on dry land so 2wd is not out of the question but mowing it is NOT a good option unless he's looking for a thicker stand of it.
   / How to remove bamboo #7
From what I read, napalm could work if the bamboo is not well established :thumbsup:
No No No! he only lives 10 miles from me I would be afraid of the fallout and that it might start growing here on my place:cool: I have enough to worry with all this Pompas grasses, which i think is about as bad,
   / How to remove bamboo #9
I asked my wife, a Master Gardener. Bamboo roots will be about 18" deep. They travel like Bermuda grass. It will die back if you can cut it off from water. If you just cut it, you're not doing anything to the root structure; it will come back with a vengeance.
Best would be check in with your local Ag Extension office for practical advise in your specific area and soils. The could recommend proper tillage, or chemical application(or both?).
http://extension.uga.edu/
   / How to remove bamboo #10
Careful of bamboo splinters. They are sharp and will go right through tires, dog feet, eyes, etc. Wear goggles and put a 12" saw blade on your gas powered weed whacker.
Bamboo is a grass. Glyphosate will kill it out.
1993 Ford F-350 4WD Ambulance Truck (A50860)
1993 Ford F-350...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
2011 Ford F-150 Pickup Truck (A50860)
2011 Ford F-150...
2021 Kubota SVL97-2HC Compact Track Loader (A50657)
2021 Kubota...
