water quality for storage
   / water quality for storage #1
BoFuller
Arizona
2008 Kubota L3400
We just put in a 2600 gallon water tank. Eventually we will be living there but for now it is just for weekends. If a tankful ends up lasting 6 months to a year, are any steps necessary to keep the water safe? Should some bleach be added?
   / water quality for storage #2
Don't know what type of tank you have but I suspect the water should be treated or it might go a bit green. I do have a filter that takes out bacteria and shale dust before it goes into my storage tank. I put a bit of bleach in my above ground 2,000 poly tank occasionally. You don't want algae or bacteria growing in your tank. :)
   / water quality for storage #3
Get a swimming pool test kit and add chlorine to keep the level at about
1 PPM free chlorine. :thumbsup:
   / water quality for storage #5
There is not a one thing works for every situation.
When water has organics in it, chlorine is not always a good thing to use with out knowing what you are doing. Trihalomethanes can be produced.
Chlorine with ammonia present in water if not having known values, can also bring you to the nitrification cycles.
Is this rain water collected from roofs, surface water off of the ground, prefiltered? Is it going to be used as drinking water?
It's water from a well in town, where you put a quarter in and the hose delivers 50 gallons. I assume it is tested on a regular basis since it is the main water source for a good bit of the little town.
Yes it is drinking water.
   / water quality for storage #7
The water quality should be a good source for you. Main thing is keep everything starting with tank and source of delivery clean.Keeping light away from tank will help control algae.
You may want to talk to the plant operator to see if he has any advice on the storage of this paticular water source and what your concerns are for time of sitting in the tank. The water plant will have a Consumer Confidence Report that maybe of interest to you.(they are free for the asking)
It may be a learn as you go with best way to keep it fresh in lengths of storage. You may even want to break down to the water you drink with a small seperate way of treating that portion versus cooking or washing your hands. It is very attainable to do what you are doing. Do not mean to make it sound more difficult then really is but, to inform you. I am in water treatment and know it is not a one way fits perfect for every situation.
Thanks for the replies! :D
   / water quality for storage #9
Bo,
Try looking at a web site, thereadystore.com they have a section on water storage that includes videos and a product that will maintain water stored for 5 years.
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
UNUSED FUTURE FT-BC63 63" HYD BRUSH CUTTER (A51248)
UNUSED FUTURE...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53472)
2015 Ford F550...
