Aaargh! 3-pt hitch not lifting any weight.
   / Aaargh! 3-pt hitch not lifting any weight. #31
If the knob is locked down, the fluid has to go through the 3pt valve via the relief valve. If the relief valve is supposed to open at 2000 psi, but it is weak, rusty, or whatever, and it is now relieving at 500 psi. That means that the 3pt will only work at and lift a load equal to the 500 psi.
If the 3pt can lift and hold a load, that means that the cyl is probably good. If you should happen to keep adding more weight on the 3pt, the safety valve will activate.
If you raise a load and locked the knob down, and the 3pt drifts down in a short time, then the only reason for this would be a leaking cyl.
JJ, Have a look at this drawing of a similar yanmar, I don't know if that is the same as other brands 3pt hitch circuits. If the control valve has a leak between the HP and Tank ports, I believe the relief valve will not trip in this situation.
Both my safety and relief valves looked to be in very good shape, i installed extra shims in each to see if that made any difference, but no luck.
The knob did stop the arms from going up/down (in the closed direction) and fall very quickly (when the lever was pushed down) in the other direction.
I really want it to be something other than the control valve, but the results of every test seem to point to an internal leak in that valve.....
   / Aaargh! 3-pt hitch not lifting any weight. #33
Close the knob [ N ], and insert a hyd gage at [ Q ]. raise the 3pt lever, and that should provide pressure to test valve.
This should test the 3pt relief, and the 3pt valve for leakage. [ L ] is the 3pt relief.
If you read a high pressure, and the relief valves activates, that proves the 3pt valve and relief are good.
I get the same results at both [ Q ] and at [ J ]. low flow 250 psi, high flow 500 psi. Regardless of the shims in the relief or safety valve. The springs look good, balls and seat look clean as well.
   / Aaargh! 3-pt hitch not lifting any weight. #35
Did you say you had good hyd pump pressure, and what was it in case I missed it?
At the low pressure you saw, the relief would never come on, and you will never raise much of a load. But of course you know this.
Did you test the cyl, by raising the 3pt and closing off the lock valve , and then loading the 3pt with some more weight. You should be able to test the cyl pressure at port [ U ].
When the loader or the remotes are hooked up, I see a relief pressure in either of those valves of 2200psi or so.
With just the 3pt hitch operating i can only see a max of 500psi when the flow is high (2000rpm).
   / Aaargh! 3-pt hitch not lifting any weight. #37
If you test the cyl, you can eliminate it as the cause, and that should indicate that the 3pt valve is not working properly.
I am assuming that you maxed out the valve in the raised position to work the cyl by applying fluid so the cyl can develop pressure.
The pressure is determined by the amount of resistance the cyl provides, but the potential pressure can bleed off before it gets to the cyl, as in worn 3pt spool in the valve, weak relief valve, weak pump, but you say the pump has developed about 2200 psi, so that is what you are supposed to see at the back if all things are working correctly.
   / Aaargh! 3-pt hitch not lifting any weight. #38
Is there a relief on the valve itself? The diagram shows a return line to the reservoir. When is it carrying fluid?
It seems like the valve is the culprit.
The valve is basically over the reservoir, there is no relief valve on the valve itself just the body of the housing.
I believe the return line of the valve carries fluid when the lift reaches its specific height from the lever position. I think there is a leak between high pressure and this return....
I will likely pull it apart over the weekend to inspect it.
I found a valve that is almost like yours and it was on a JD 790. I would start at the 3 o rings then to the poppet under cap #7 and #10. That valve under 7 goes all the way to plug 10. If it was me I would take the hole valve apart now that you have the brake down. If # 10 is a hex plug then you should look at the JD790 parts list, also you can read the parts names. I'm sure you checked lever linkage of anything loose or broken right?
I never would have though to look at the 790, I had concentrated on similar model years as my Yanmar.
I managed to get a shop manual for the 790 with excellent diagrams and procedures. I will post some pictures and drawings when I get it pulled apart.
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
Air Compressor (New/Unused) (A59225)
Air Compressor...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
