Ford 907 flail 6'
   / Ford 907 flail 6' #1
Steve O
I have an old ford flail mower and the cross shaft bearing went out a couple of years ago i just got the time to fix. I used a mic on the bearing bracket and cross shaft and got 1.1635" on shaft and 2.800" hole size for flangette I'm trying to go to tsc for parts but want to know the size to get. Any input would help.
   / Ford 907 flail 6' #2
These open bearings like all bearings are metric in actual size,
you should plan on changing both flail rotor bearings as a matter
of principal and piece of mind for your mower.
If you look at the flailmaster catalog on line you should be able to find the bearing. I will check my catalog quickly and see if it is there now.
Edit
I found bearings for the 918H but not the 907. The folks at flailmaster would know what you want for sure if you call them on tuesday.
One of the other members here has manuals and can probably tell you which bearings you need for sure.
Welcome to our newest member of the Flail Mower Nation.
Only 17,997 mowers to go.
_________________________________________________________________
Once you go flail you never go backthumbsup::licking::drool:
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
