Newbie with Ford 4000 Rear Axle Leak
   / Newbie with Ford 4000 Rear Axle Leak #1
BAG
Central North Carolina
'69 Ford 4000
I have a 1969 Ford 4000 with a leaking left rear axle. The tractor has been parked in my driveway for a month or so and there is a pretty good size puddle by the tire. The local New Holland dealer quoted me $600 to replace the seal. Is this a difficult repair to make? Any guidance would be appreciated.
Alex
   / Newbie with Ford 4000 Rear Axle Leak #2
is it leaking at the outter side ofthe trumpet near the hub? or inner side near planetaries / brake rod.. or a 3pt arm mount? or pto shaft and then running down?
chek yer service manual and parts manual for a breakdown.
do you have the tools and equipment, including stands, cribbing and preferably a cherry picker or overhead hoist to do the repair? if not... then it's 'easier' to pay someone to do it.
soundguy
   / Newbie with Ford 4000 Rear Axle Leak #3
soundguy
it wouldn't be the 3pt arm mount because they pin into casted ears that hang down like on a 5000. i would be checking the brake rod seals first because they are easy to change. if it is the axle seal by the hub you will have to remove the tire finder lift arm brake rod and trumped housing off the rear end then remove the brakes if you dont have cut them out and them press the axle out of the trumped housing. So it could be a real easy job or a major job but nothing in between
   / Newbie with Ford 4000 Rear Axle Leak #4
i asked about the 3pt arm mounts for him to look if it was running down there from the pto shaft seal and dripping off. seen lots of leaks that ran a few feet then dripped far from where they were leaking... thus I wanted him to check out the actual location of the leak.. not so much the location of the drip...
soundguy
Thanks for the input guys. It appears the leak is from the end of the axle immediately inboard of the rim. The fluid drips onto the inside of the rim. I have the tractor parked in my driveway and the ground slopes slightly downhill toward the leaking side. It has been sitting there for a few weeks and there is a pretty good sized puddle on the concrete adjacent to the tire.
   / Newbie with Ford 4000 Rear Axle Leak #6
you rear axle seal is leaking and that is a major job if u dont have a few big jacks and chain falls
   / Newbie with Ford 4000 Rear Axle Leak #7
How did you change the seal? It appears to be fairly easy, but I wonder when the axle is pulled, does it hurt the planetary pinions? Is it easy to reinstall? I am having the same problem and needing to know what to expect. I appreciate any insight and advise.
Mark
CATERPILLAR 239D SKID STEER (A51242)
CATERPILLAR 239D...
2018 John Deere 333G (A47384)
2018 John Deere...
INSPECTION (A51572)
INSPECTION (A51572)
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
