Well problem with a simple and happy ending
   / Well problem with a simple and happy ending #1
MillWeld
Gold Member
Durham NC
Ford 641
When first turning on the fawcet the water would come out with great pressure and after prolonged use the pressure would drop very low with the flow almost stopping. I took the pressure switch off and noticed the standpipe (the short brass 1/4 inch pipe connecting the pressure switch to the tank fitting) was nearly completely clogged. It became clear that the clog caused pressure changes to be sensed very slowly allowing pressure to build up very high and fall very low. I reamed out the black crystalline crud in the pipe 'til it was clean, reassembled everything and normal operation resumed. If this had gone unremedied the pump could have soon run indefinately and caused more (expensive) problems. I've lived on well water for 40+ years and this is the fisrt observation of this problem. Anybody else seen this?
Bob
   / Well problem with a simple and happy ending #2
Yes, I'd say it's pretty common in areas with water, containing certain elements. Don't know what they are ... iron, etc.. ??
   / Well problem with a simple and happy ending #3
Happens all the time - every year I drain the tanks and remove the boiler drain valve and run a wire up the 1/4" pipe leading to the pressure switch.
At the same time I change the filters, and check the tank precharge pressure to 38PSI (2 PSI below the 40 PSI cut in pressure).
So its a "standard" maintenance aspect to having a well with high iron or metals content (iron in our case).
Carl
   / Well problem with a simple and happy ending #4
Bob
yep.. in florida mineral water I usually plan on replacing the pressure switch about every 4-5 years at least, and the stand pipe at least with every other switch. have seen some eat up from the inside so thin that removing the pressure switch broke the stand pipe at the threads, making me use a large flat blade screwdriver to extraxt the remnant of the thread..
soundguy
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
2025 Swict 66in Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
2016 Ford F-150 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
