tractor tire repair kit (tube type tire)
   / tractor tire repair kit (tube type tire) #1
accordionman
Gold Member
wright city, mo.
KUBOTA L3000DT, FEL.
HELLO,
years ago, i can remember tire repair kits being
available, with a sheet of rubber, that you cut with
sissors, and a tube of glue. i tried three places today
to buy one of these kits. everyone i talked to was not
aware of these kits. they are no longer available. my
tractor tires have tubes, that i can repair, if i can find
the proper parts. all of the repair parts i found are for
tubeless tires. cars, trucks, and?
what type of tractor tires do you have? comments please.
is there some other place that i should be looking?
accordionman
wlbrown
   / tractor tire repair kit (tube type tire) #2
like these?
Walmart.com: Search Results for "tire patch"
Search: tire patch | Tire Patch | AutoZone.com
I would also consider any auto pars store you should be able to nug some good quality ones. to buff the tube I use sandpaper in the past also.. The 'glue' or vulcanizing glue is also needed.
Simply locate the hole, and then estimate the area that the patch will cover.and buff it and a litle byond and then apply the "glue" and left dry then apply the patch without touching the side that geos against the tire or tube.Then you need to roll it . There is a wheel on the end of a handle you can buy and is well worth it
Auto Car Compating Patch Repair Tire Wheel Roller Tool | eBay
, but ive used hammer head and pressed it. with good results,
Hope this helps
HELLO,
i found it. i did a search on VICTOR rubber patch kit,
and found exactly what i was looking for. the number was
V406, and i placed an order. i had tried autozone, and napa,
and walmart. amazing what you can find online.
thanks to all that replied.
accordionman
wlbrown
   / tractor tire repair kit (tube type tire) #5
The Camel brand was what I helped my dad use in the 1940s. The tubes were red as well as the rubber patch material. The can lid was made so it could be used to clean the patch area. Cut off a square of patch material the size needed, spread some adhesive glue over the cleaned area, light it with a kitchen match to make it dry faster. Peel the white backing off the patch material and stick it to it.
I'll keep VICTOR in mind next time I need to patch. Thanks
ANTIQUE CAMEL TIRE PATCH KIT EMPTY CONTAINER COLORFUL | eBay
   / tractor tire repair kit (tube type tire) #6
just found this on Amazon
Amazon.com: Xtra-Seal Chemical Vulcanizing Cement (8 oz.): Automotive
lower to the botom is a deal with patches also in it..for 16 ..delivered.
just order this stuff too...
awesome, thanks
   / tractor tire repair kit (tube type tire) #7
HELLO,
accordionman
wlbrown
if you are stuck check the bicycle parts aisle for patches at wally world/kmart
tsc or other ag stores usually have a good assortment of patches including tire boots for thee bad cuts
UNUSED HURRICANE 6' X 11' CONTAINER (A51248)
UNUSED HURRICANE...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
2023 John Deere 8R 280 MFWD Tractor (A53342)
2023 John Deere 8R...
16ft Bumper Pull Trailer (A51572)
16ft Bumper Pull...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
